Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Seagate external hard drive problem
My external hard drive is not recognized , it was before but not it is not, it keeps saying a device is unknown, i tried to restore but it did not work My Seagate FreeAgent Go 250gb portable hard drive isn't recognized anymore. I tried to disconnect and reconnect, tried to connect a flash usb drive, and different cable and nothing works. I also tried to connect it through other computers and still nothing. All the hard drive does is make the "I'm working" sound and light up but it doesn't show up at all in computer or the computer won't even make the connected sound. when it stopped working was when I tried to run a program imgburn and it said the program wasn't responding and then I closed it then ran it again and then I went to my folder on the hard drive clicked so I can burn and it said that it was unavailable. Then I disconnected the hard drive "safely" then connected again then it didn't show up. Did I do something wrong or is it just a ironic? or is it dead? :(
  • 63 Answers
I have the same problem with a 500GB HD by the same maker. Fortunately mine started throwing "delayed write failed" errors regarding the MFT. I had enough time to save my data. Your event log should say something to point you in the right direction. Make sure your pc is up to date with the latest service pack too and start looking for a new External HD. Tiger Direct has great deals. I got a 1TB for about $120 Good Luck!
Posted on May 30, 2009
How can I retrieve data on a dropped/malfunctioned seagate portable expansion drive?
Not a DIY task. You need a professional with data recovery skills. There are few good ones around.
Jul 07, 2014 | Seagate Expansion 1.5 TB USB 2.0 Portable...
How to recove Seagate external hard drive data?
Probably, the new operating system cannot recognize your Seagate external hard drive. You can connect the Seagate external hard drive to another computer to copy data to another device. If the problem still exists, you might need to perform data recovery. You can free download the data recovery software: http://www.icare-recovery.com/seagate-recovery/seagate-external-cannot-be-recognized.html
May 14, 2014 | Seagate FreeAgent Pro 500GB External USB...
My seagate 500gb external hdd recognize in device manager.
I would get a bootable linux distro and boot up and use the partion manager there. (knoppix) If that does not work I would get the factory diagnostic tool from seagate and if it gave errors return it for warrenty or if not under warrenty least you will know there is something funny with the hardware.
Mar 23, 2014 | Seagate Computers & Internet
My Seagate 1TB FreeAgent external Harddrive is not working on my laptop which is running on XP. In Manage Hardware section this device is shoing as unknown hardware.
go here
And download for windows. You see most companies like you to download the software from their website for older operating systems for your computer to recognize it.
Thanks, Cody
Sep 11, 2012 | Seagate Freeagent Go 1 TB Hard Drive
I cannot boot my PC when the seagate hard drive is attached. I have to disconnect the external Seagate drive and then boot. Once booted I can physically plug in my seagate External Hard drive and it...
restart the system, while restarting , press delete/F8 to enter in BIOS menu, select boot priority and select the primary HDD as first boot device, deselct the "boot otehr device" option.
it should work fine.,
Cheers!
Sep 11, 2010 | Seagate Computers & Internet
Unknown device!
Keep trying, it won't work until you download the right drivers.
Oct 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computer cannot recognize the drive now, after months of use.
Check the Adminstrative Tools status.If it says unallocated,it needs to be either reformatted or recovered.
Sep 10, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
My laptop HP zd8000 doesn't recognize Seagate external hard drive
hi..the reason for your problem is your extenal
hard drive has been affected by viruses.The best
solution to this problem is scanning your hard drive.
once you scan it u will be free of viruses and your
laptop will be able to recognise your hard drive.
try it out..
thank u..
rate me..
Feb 10, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Dec 30, 2008 | Seagate FreeAgent Pro 1TB External USB...
Hello, Did you try to use this drive on another computer? Did you have the same problem? Did you try using a different cable? I would try these things first in order to determine if the problem is with the drive or with the computer. Good Luck! Dr. Know
Dec 23, 2007 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
760 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
