Question about Miele Novotronic Premier 500 Front Load Washer
Miele W830 i have a problem on a Miele W830, when the wash starts the water from the detergent tray comes straight out the drain pipe behind the door., and doesnt fill the Drum ive cleaned the tray, and while the tray is removed i poured water straight into the pipe which leads down from the tray, again, the water came straight out the drain pipe behind the door, the filter is clean, as this is checked every month, as is cleaning the tray......this is the first problem with the machine in 15 years! My Miele W830 has started behaving erratically, for example when I press the door button the barrel starts to rotate but the door won't open. The last wash didn't complete the cycle either and it took a long time to get up to spin speed then faltered & just rotated slowly. Is it repairable?
SOURCE: miele W830
I have exactly the same problem - what was the answer ?
Posted on Apr 05, 2008
IB4G2008
  • 3587 Answers
SOURCE: water not getting into washing machine miele novotronic w830
K5? which pipe is that..let's assume you have pressure to the back of the unit, yes? then you have a valve sticking or something obstructing the channels inside that unit..
does this work regardless of temperature setting.
Posted on May 10, 2008
  • 70 Answers
SOURCE: Which water pressure does a Miele Typ W830 need
Hi Mimimun flow rate is 5 litres in 15 seconds or 1 bar
Posted on Apr 17, 2010
Testimonial: "very good and fast feedback. Thanks! B."
  • 177 Answers
SOURCE: Miele novitronic w830. Drain wont work
Have you tried checking the drain spigot under the sink where the waste hose connects as it can be blocked at this end?
Try draining the unit into a bucket instead of the sink this will eliminate the washing machine as being the problem if it works ok.
is the drain pump actually turning? select drain or drain spin and have the fluff filter (outlet) removed so you can see if it is turning. if it isn't turning there maybe a broken wire to the drain pump causing it not to turn or the drain pump is jammed with something although you mentioned you could spin it freely.
hope this helps
Posted on Jun 01, 2010
  • 3 Answers
SOURCE: Have a Miele W320, during the rinse part of wash
Is the drawer gunged up? Are you using too much detergent?
Remove the drawer, and clean it with hot water and a brush.
Look into the empty drawer slot for any blockages and remove.
Replace drawer, try pouring hot water into the open drawer to try to dissolve and clear any blockages.
Consider using a dosing ball and adding detergent to the drum.
Posted on Jun 30, 2010
ALL LIGHTS ON PANEL ARE FLASHING??
All the lights on my incognito started to flash. This was after the drain/intake light started to flash also. I called Miele and they helped me to reset the lights flashing. They said that when all lights are flashing that this indicates an overheat condition. They asked if my filters were clean and I thought they were. However, my wife had started to use liquid dish washing detergent and the liquid detergent had plugged up the filter screen at the bottom of the dishwasher. I cleaned it good with a scrub brushing and boiling water. This fixed the problem. Bottom line, don't use liquid dish washing detergent in a Miele, only powder.
Apr 08, 2014 | Miele 24 in. Incognito G843SCVi Built-In...
The check drain light on my Miele Novotronic W844 washing machine is flashing; I have drained water out from the drain pump/filter section behind the panel at the front then refilled water in the detergent...
Hi dear.Related to your explenation: It does have faulty pump but first checked the pump harness.That's important.If every thing seems OK then you can replace the pump.I hope that helps.Thanks.
Feb 13, 2011 | Washing Machines
W4840 water proof system activated how to reset
1. Unplug the washer
2. Tilt the machine forward about 45 degrees
3. Water will start pouring out from the base pan. Have some towels handy to clean up.
4. Put the machine back in its position
5. Plug it
7. You should be ready to go
Causes
- You may be using too much detergent. Try lesser amount next time.
- There is a leak. If using less detergent does not solve it and this message keeps coming back, then the leak needs to be investigated.
Dec 10, 2010 | Miele W4840 Front Load Washer
We have a Miele W830 Novotronic washing machine. Water started pouring out the bottom l.h. door from drain pump area when we tried to do a load of washing tonight. We've taken it out and cleaned it...
Although this answer is obviously not current any more I thought it may help others. We recently had the same problem with our machine. The clamp holding the hose to the detergent drawer became loose and the hose came off, allowing water to pour right down to the drain pump area. By undoing the 3 screws behind the detergent drawer + the 3 bolts around the door, I was able to open the front of the machine and tighten the hose clamp.
ozfix
Oct 18, 2009 | Washing Machines
Miele Dishwasher is not cleaning dishes
check the filters. also check drain. Sounds like it's not fully draining and/or there is not enough water (ie. when filter are clogged)curculating to wash the dishes properly
Jun 08, 2009 | Miele 24 in. Incognito G843SCVi Built-In...
When I use cold wash on my Miele W830 the water heats. Any solutions?
check the water connections going to the back of the machine, you may have the hot and cold mixed or reversed. if you turn it on hot water will it dispense cold water?
Jun 30, 2008 | Miele Washing Machines
Miele Novatronic W360
there is still water in the waterproof tray at the bottom of the machine and the float switch has activated. pull the machine out (if pipes allow) and tip the machine backwards to drain the water from the tray.
Jun 01, 2008 | Miele Novotronic W1918A Front Load Washer
Water not getting into washing machine miele novotronic w830
Thank you for advice! My Miele Novotronic W830 is 17y old, been working well, until yesterday. When taking water, much started spilling on floor under the left lower corner of the machine.
I opened the cover, found a loose hose under the detergent tray, did set it back in place and tightened the band.
First you better loosen the band, it slips more easily on the funnel.
In my photos you can see the screw is pointing to wrong direction to be able to use a screwdriver, but I did manage it with bare hands.
Be sure there is no power connected when opening the cover!
And don't drop anything inside, when opened the cover, it is a nasty place to get it back...8_26_2012_3_23_27_pm.jpg8_26_2012_3_24_22_pm.jpg8_26_2012_3_24_47_pm.jpg
May 10, 2008 | Washing Machines
Miele W830
Mar 15, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
191 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
