Question about Panasonic PT-61LCZ70 Television
TV turns off every five minutes and lamp light flashes red 13 times, it keeps on doing it over and over....Lamp is okay since once start it again picture is perfect as well as sound.
Panasonic TV turns off every five minutes and lamp light flashes 13 times model PT-61LCZ7.
SOURCE: panasonic pt-61lcx65
I have the same TV and just replaced the same lampTY-LA1000.
You have to reset the clock that times the lamp.Hold down the volume button(first you turn on the TV) while holding down the PiP button or the swap Button on the remote. that fixed mine.
Posted on Feb 10, 2008
SOURCE: no picture
There are other things that can cause the image to go away besides the lamp, like a color wheel, a ballast or a dmd board. Replacing the lamp is very easy you just need to open the back of the Tv, unscrewing everything, take out the housing, unscrew it take out the lamp, put in the new one and screw everything again, also make sure that you close everything perfectly because if you don't the lamp might not light up.
Posted on Jun 30, 2009
SD Tech
  • 14553 Answers
SOURCE: MY PANASONIC PT-61LCZ7 NEEDS A LAMP. I AM IN
part number for the lamp unit is:
LFS4000PA1EB It has a suggested list price of 605 dollars and is not customer replaceable----it also requires TECH approval from Panasonic to order----this is one of the 2007 models with a led type lamp--have to dismantle set to replace--no shops here will do it in the home---lamp wholesales for under 300 but has substantial core charge---they rebuild all these.
I hope this helps you---You can also Google the model number and I think you will find some used ones but no new ones.
sd tech
Posted on Oct 01, 2009
SOURCE: my panasonic pt-61lcz7 HDTV
Was it because the light bulb burned out on the back projection TV? I'm having same issue now. Did you solve the problem?
Posted on Nov 26, 2010
  • 160 Answers
SOURCE: Panasonic PT-61DLX76-K TV, no picture, red lamp
Hello.
Lamp should be replaced in average every 2.5 years. Bad lamp could look OK but it is not.
Replace the lamp first if it is older than 2-3 years. You have to do it in any case. If new lamp will not
work, only then you can start thinking about ballast replacement.
If you are OK with the screwdriver and you have technical skills you don't need service manual to replace ballast. You will need to remove rear cover and locate it near the lamp. It is not too hard.
Regards.
Russ.
Posted on Dec 01, 2010
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
Sony KDF-55WF655 'rebooting'?
Replace the lamp . p/n XL-2200
Oct 05, 2009 | Sony KDS55A2000 55" HDTV
Panasonic PT50LC14 No Sound or Picture
unplug it, and let it set for a minute or 2, then try it again...if it does it again hit the power button again to turn it back on...also once the the tv turns on make sure you reset the counter for the bulb..that will also cause problems...to reset the counter press the (-) volume on the tv while holding down the (-) press spilt,pip on the reomte...the lamp will reset and the indicator will go out
Jan 20, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Tv turns off tne comes back on
Please count red light flash again.
5 times flash shows Lamp Error.
6 times flash shows No "DD 6V " output (G1 board) Its bit technical term.
Need fuhrer help, please Post it here.
Thank you.
Sep 21, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
Sony KDF-42WE655
Bad lamp and/or lamp driver. Try replacing the lamp first.
Aug 20, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a LG RU-44SZ61D DLP TV and recently replaced the bulb. After about two months the TV went really dim and then started shutting off. The problem increased to the point where you couldnt have the tv...
DLPs have flow chart trouble shooting techniques to pinpoint exactly why your set isnt completeing the boot sequence. If you would like the service manual for your model let me know and i will post a link where you can purchase a complete one.
Apr 06, 2008 | Televison & Video
Panasonic PT-61LCZ70 Television Logo
100 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
