Question about Compaq (252608-001) Motherboard
Monitor comes off and on
Pls my PC some times goes off and comes on again, so I want to know the course of it and propably get a solution from you.
Pls I also want to know the best way of reparing a crashed hard drive.
  • 3 Answers
MOTHERBOARD MAY BE FAULTY CHECK  AND REPLACE IT
Posted on Oct 22, 2007
Optiplex 745 monitor goes to sleep randomly
In regards to your issue with your monitor: For a monitor to display "no signal input" there is likely a problem with the monitor making a connection to your input source (yes I know duh). First and easiest thing to fix this is to check your cables going between your computer and monitor, if your computer and monitor start out working and then fail to communicate, there is a good chance that the cable might be coming loose just enough that the connection fails. I might suggest that if you have, as you say another computer, that you try swapping monitors to check where the problem lies.
Hope this helps some.
Aug 12, 2013 | Dell OPTIPLEX 745 PC Desktop
I have an HP Pavilion PC and Monitor. When I switch on the PC start up is fine and the monitor shows it going throgh the start up process - monitor then goes blank and i cant see anything. if i switch the...
To make sure if the monitor is really troubling u, try using it with other fine PC. If it goes fine with other PC, then consider whose fault is that.
Sep 28, 2010 | HP Computers & Internet
I have a Philips 170S4. On startup it displays the memory check fine. Then everything goes black, the green light indicating the monitor is still on is still lit up. I can only JUST see some pictures on...
did you adjust the brightness, also in windows settings?
pls check with another monitor ,also you can check monitor with another pc or laptop
try with reset the monitor settings
also change the resolution and display frequency
Oct 03, 2017 | Gateway FPD2275W LCD Monitor
My 740N Samsung monitor is auto sleeping
either mobo or video card, try resetting cmos on mobo
Jun 02, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
I have a hp a305w. Last night it worked fine, today nothing.
Most propably it is the RAM that is making troubles. Before doing anything - first change the RAM.
Feb 15, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Screen flickers
ram problem once clean the ram and insert it again if the problem occurs again the change ur ram it will rectifye ur problem
Jan 22, 2009 | HP Pavilion MX70 17" CRT Monitor
Screen suddenly goes blank
when you open your pc now,do you still hear a click sounds like you hear before ,when your computer has no problem yet? now there is no sounds .do the ff..
1.try to press the numlock key and observe it ,if the indicator LED lite on and off,the problem of your computer is your video card,
2.if you can't hear anything, when you open your unit and the indicator of your monitor goes the color orange,pls..check your memory .clean the memory and the memory slots using the contact cleaner .before you replace a new memory.
3. and try to use a another monitor,maybe your monitor has the problem.
Apr 01, 2008 | Samsung SyncMaster 551 15" CRT Monitor
Black Screen
No, this is typical problem for defective inverter. Mostly screen appears for some seconds and then turn to black. If you are technician, you can use this link :-).
http://www.lcdrepair.us/1702inverter1900x.html
Oct 01, 2007 | Dell 1703FPs 17" TFT LCD Flat Panel...
Wireless crd
Hi alioops, unless you're using a laptop with the FS7600, normally you can't use or install the netgear wireless pc card (WG511;PCMCIA Card) to a regular desktop computer. If however, you're using a laptop, then you have to find a narrow rectangular slot normally at the side of the laptop with flip or hinge cover. Merely pushing in the Netgear Wirteless PC Card into the said slot would physically install it. Of course, it has to fit snugly and perfectly in order to work. Further you may have to install the drivers that are in a CD that comes with the card. Hopes this works for you. Pls post again how things turn up. Kind regards.
May 26, 2007 | HP Compaq FS7600 17" CRT Monitor
Monitor keeps blank even the power lLED is on green
I suspect the problem is with the monitor itself. I have had the same problem. I reported it to Dell and they sent me a new monitor within a few days the problem resurfaced again on the new monitor. They have since sent me a new monitor and the problem has disappeared. The Dell customer service people sounded rather cagy to me when I suggested that this was a problem endemic to this model. The replacement monitor that I have had a sticker on the box that read "refurbished". This is a rather new model of monitor to already be into selling "refurbished" models. If you are still under warranty I suggest you call them. And even if you aren't, call them anyway. I sense that they know about this problem.
Oct 23, 2006 | Philips 105S51 15" CRT Monitor
Compaq (252608-001) Motherboard Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
