Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Ref light bulbs and noise no cooling wh-pool GS5SHA
Open door, loud buzzing noise, all 3 light bulbs flash. (new bulbs) freezer lights unaffected push button (on - off) on side works smoothly noise coming from bottom of box I have the same problem as aferalcat with my Whirlpool side by side...started last night with noise & all lights flickering on refrigerator side. Came in tonight and no cooling on either side. Probably can't get a repairman out this weekend!!
I had the same problem. There is a main controller board at the bottm of the refrigerator near the back by the compressor motor. One of the components on the board shorted out and the board had to be replaced. Total cost about $150.
Posted on May 30, 2009
Light blinks off and on when door is open
If you mean that the freezer cabinet light flashes check the lamp fitting and ensure the bulb is fully tightened, they have a habit of becoming loose with the expansion and contraction of the fitting/bulb as the freezer compartment cools with the door shut and the bulb warms when the door is open.
Jan 09, 2014 | LG LFD22860 Bottom Freezer French Door...
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
Light bulbs are flashing with constant pulsing noise
It sounds like you have a lose connection for the lighting. It may be at the light bulb socket or even at the door switch. It also could be a lose wire going to or from these items. with a little detective work you should be able the bad connection.
I hope this helps :)
Apr 21, 2010 | Whirlpool GD5SHAX Side by Side...
Ref light bulbs wh-pool GS5SHA
Your refrigerator has two sets of electronic control boards. One is inside and works to adjust temperature and to communicate with the other below and behind the refrigerator. They both have relays that if bad could cause the sounds you hear. It would be ok to pull it away from the wall and open bottom cover and listen to see if the sound is coming from the lower control board. If yes we need to examine the board after unplugging the power to refrigerator. let me know if the board is the reason or if while there you find something different, Thanks, Sea Breeze
May 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ge profile buttom freezer cold refrigerator hot
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Dec 17, 2008 | GE Profile Arctica Stainless Steel Top...
Fridge and freezer not cold. Loud buzzing and clicking intermitently. Lights flashing to say door is open and all freezer temperature lights are all flashing too
Read this article on Compressor Relays to understand the problem you are having.  It will explain in detail what to do to repair your machine.
Thanks, Bill
Nov 09, 2008 | Whirlpool Refrigerators
Loud Buzzing Noise from Behind Freezer
Sounds like the freezer fan blade is hitting on a build up of ice or frost. You may have a defrost issue, or it may be a one time thing, like the door was open for a long time (object holding door partially open) or also check the ice dispenser duct door to make sure it is closing. Sometimes a chunk of ice hangs up in the ice shoot, allowing moist air to enter freezer, resulting in the extra frost / ice near the freezer fan. You might also check the door gaskets, especially the bottom side where sugary liquid spills might cause a gasket to tear. #2: Long run times: If cooling is good, don't worry. Older refrig's often ran less time, but used much more electricity than the newer refrig's, even though new one run longer. (Like having a 40 watt light bulb on for 20 hours a day uses less electricity than having a 100 watt bulb on for 10 hours a day)
Aug 27, 2008 | GE PFS22SBSSS Stainless Steel French Door...
BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
Apr 08, 2008 | Refrigerators
Whirlpool gold fridge model GD5SHAXNSOO
Have you got a screw loose. One which holds the door light switch. is it the switch which buzzes?. I had a fridge which didn't get cold. When I scrapped it I found that the retaining ring for the switch was not tight enough and r4ealised that the light had been on when the door was closed.
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
188 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
