Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
No display on switching on the pc, the first screen appears and and it disappears. then the screen goes off and power led starts blinking. and that's all. it's the problem
  • 3 Answers
Re: no display
Posted on Oct 22, 2007
0 characters
3 Points
Blue screen error appearing while installing Windows XP. I cant install windows xp. plz help me. I want to install windows xp.
format the drive in which you have XP before , then install a fresh copy of XP
then when XP's finished first of all Update your drivers first.
Find out what graphic/video card you have.
Start Menu > Run > Dxdiag > Go to the Display Tab >
It should say the Name of the Graphic/Video card.
After you find out the name just google the card and find the drivers.
Install it and see how it works. good luck do vote
Mar 31, 2011 | ASUS K8V-MX Motherboard
Pc not starting from pressing power on. Green LED for SB_PWR is on and when power switch pressed, fan & cool fan flicker momentarily but nothing happens. They do not spin. No LED light appears on front...
> PC had been suddenly powering off several times intermittently for a few days leading up to this state. Does this mean the PSU or Motherboard is at fault?
Yes, either CPU or PSU or motherboard are the likeliest culprits.
It's easier to try a different PSU than to try a different CPU or motherboard.
Nov 18, 2010 | ASUS K8N-E Motherboard
Gigabyte GA-945GCMX-S2 Motherboard having display..
At first I thought your screen went black during the start up process. After seeing the bios screen. In which case I would've said it was a bios setting for the display. Then I realized that I think you mean that their is no display at all. When you push the power button. Only the monitor led light. So, it may be a problem with your RAM stick/s. You should make sure that they are properly seated in the mother board. If they are new, make sure they are compatible with that motherboard. If you can you should swap them out with known good ram sticks. You could also try installing a video card and see if you can get display to work through that one. Make sure your main power supply wire connector is pushed in all the way. Swap the power supply with a known good one if you can. If still can't get it to work you may want to take the motherboard out and inspect it for burns, cracks, and anything that doesn't look right. Maybe contact the manufacturer of the motherboard and ask them what you can check. hope this helps.
Sep 17, 2009 | Gigabyte GA-945GCMX-S2 Motherboard
No display
Are all the other LED Blinking. Fans revolving, etc but no power at the keyboard or mouse(if optical), then the problem is with the keyboard or one the pins of its PS2 connector might be bent. Try a different keyboard and see if the PC boots up.............sodeep
Mar 31, 2009 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
Unpluging 4 pin power on mobo Pc starts but no video,keyboard etc
how do i fix the monter I tryed to put the power and rest on and motherboared comes on not the monter
Mar 13, 2009 | ASUS P4SGX-MX Motherboard
are you using socket 478 motherboard or socket lg775 motherboard? if lg775 mobo you using try to remove the cpu heat sink and put it back again make you put correctly lock it perfectly and try to switch it on
Mar 12, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Presario SR1030AN Turning on but not booting or POST or no any beep at all.
Have you tried switching the power supply out with one that is known good?
Nov 26, 2007 | ASUS A7V8X Motherboard
No power and blinking green LED
It may not be that the bios needs clearing, take the left side panel off and look for the 'JBAT1' terminal on the mobo and put jumper cap from pins 1-2 to pins 2-3 for a few seconds then back to pins 1-2. start the pc then set the time and date when prompted ans save settings.
Feb 09, 2007 | ASUS K8N Motherboard
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
62 people viewed this question
Top Intel Motherboards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you an Intel Motherboard Expert? Answer questions, earn points and help others
