Question about Acer Aspire 4520-5582 Notebook
My monitor does not work
Nothing shows up on the lcd monitor and when hooked up to an external monitor it only works when it is in safe mode, when rebooting in normal mode the monitor goes dead acer won;t fix it,i returned mine,I had to pay 30.00 shipping,they sent it ack after 2 weeks and said it was repaired,iI turned it on and it was NOT rpeaired,my backlight still didn;t come on...after returning it to them for repair.Aer is junk.I used my laptop about 2 weeks.It is hooked up to a desktop moniter,so it is now used as a desktop computer,as i cannot move a desktop moniter around with me.JUNK JUNK JUNK Acer is no good.
  • 159 Answers
First reinstall the xp
Posted on May 30, 2009
Laptop broken screen... plugged in Dell monitor,still doesnt work
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 03, 2012 | Computers & Internet
Just hooked up my pc yesterday worked fine. I shut down by going to start & turn off computor. Came back later to start back up. Monitor tells me in power safe mode. Tower doesn't seem to be starting...
You can try removing external devices like (ex. usb printer, external Hard drive) and try to start the computer again. And see if there are lights on the tower
Hope this helps
Jan 03, 2010 | Dell E173FP 17" LCD Monitor
We have the monitor hooked to a docking station for a laptop. I can not view the screen on the Viewsonic, but does display on laptop. I have been able to do an extende monitor view, but not the main view....
when you connect external monitor to a laptop u get two options in the monitor section of graphic properties tab
1.) extended
2.) clone
it is clear from ur post that u are using extended view
try using clone mode then both laptop screen and external monitor will show the main screen
other method is to disable the laptop screen and just allow external monitor to work, in this case laptop screen shows nothing but external monitor shows main screen
Sep 29, 2009 | ViewSonic VG700b 17" LCD Monitor
ACER cracked screen..external monitor???
Hi there.
The keyboard toggle you are using is the correct one.
Sometimes you have to hit Fn + F5 a couple of times to stay on there is no real set time. Make sure Fn + F6 is on so the laptop screen stays on.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
grabe a flash light and look at the notebook screen see if you see a show of the desktop if you see icon etc.. that means your blacklight of the notebook is defective. sorry to hear that
Apr 15, 2009 | Acer Aspire 4520-5582 Notebook
Lcd screen broke external monitor wont work
Sounds like you resolution is too high or vista doesn't recognise your driver.
Try starting in Safe Mode by powering up your PC and tapping the F8 key until you see a menu. Select Safe Mode from the menu. Once in safe mode change the resolution to 800x600 then restart in normal mode.
If that doesn't work then download and install the correct drivers for your display card here;
ftp://ftp.work.acer-euro.com/notebook/aspire_3680/
Once downloaded, you may need to install it in safe made once again.
Thanks
C
Mar 28, 2009 | Acer Aspire 3680 Laptop
Vison flat 19" hooked to toshiba laptop w/Vista no signal
Can't say I really "fixed" the problem. I tried other monitors, DVI cord and took the laptop to a repair shop. Nothing worked. And then....boom.....it worked! No one knows why or how. No one did anything to the computer or monitor. It just works. Who knows how long it will work, but it works today.
Jan 19, 2009 | TDV Vison TDV FV19B 19" Flat Panel LCD...
Monitor is in power safe mode
your resolution is set too high go into safe mode and turn the resolution to min and then play with it until it shows nothing push the space bar and leave the setting on that
Nov 18, 2008 | Dell E153FP 15" LCD Monitor
Proview 700P lcd monitor problem
Your monitor has been enabled as an extended monitor, not a clone.
Easy way to see is open a window, grab it and drag it to the other monitor (drag it right, not left). Just remember even if you have the external monitor on your left side, it is really on the right side according to the computer.
Check the display properties for a clone option if you want both to show the same thing.
Hope that helps a little.
Apr 09, 2008 | Computers & Internet
Dell Inspiron 6000 monitor display problem
Well it is most likely a issue with the Video driver as you are able to boot to the safe mode.I would suggest going back to the safe mode and deleting the present driver for the video from the device manager.before you restart the system just download the latest version from the support.dell.com so that you can reinstall it.Also check in the graphic properties which screen is set to be the defuat.Incase still not working i would suggest reinstalling the operating system before replacing any hardware.
Jan 03, 2008 | Dell INSPIRON 6000 CENTRINO...
Acer Aspire 4520-5582 Notebook Logo
219 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
