Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirl pool side by side refrigerator problem
The side by side refrigerator failed to cool.
Found that the refrigerator side by side would turn on, fan etc.  Then the compressor hum would begin followed by a click(sounds like a contact click) which would stop the compressor start operation.  The compressor start up buz would begin until a click would stop the function.
The problem is getting progressively worse -
Now when I plug the refrigerator in  there is light but - no motor hum or fan function.
"What is going on!"  My unit is only three years old!
  • 1 more comment
  • Jackl Nov 05, 2007
    I have the exact same problem with mine. Initially it would shut itself off for a while, the contents would start to warm up and then it would return to normal. Over the weekend it stopped cooling and simply hums and shuts off. The unit is 6 years old. Is this too costly to repair and am I better off getting a new one?
  • emmittzone Nov 24, 2007
    The refrigerator light is flickering and the unit is making a humming sound.
  • Anonymous Mar 17, 2014
    fridge which was just cooling/freezing functioning properly just stopped .this happened when someone tried to push it from where it was placed.I do suspect the compressor to be faulty as there is anything functioning now.
Actually its more likely a faulty compressor.  the components are doing what its designed for and interrupting the compressor because its tight.
Posted on Oct 24, 2007
It looks like the Capacitor Start Relay is failing.  It is located either on the starter Relay or mounted on the side of the compressor compartment.  It sould have two wires on it, one orange and the other probably white.
Posted on Oct 22, 2007
Does sears have a lite for the freezer side of the whirl pool freezer?
the take the old light and go to lowes or the hardware store or any appliance parts store and they can help you with the correct light . most standard are 40 wate appl type . .. mm
Feb 01, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I purchased whirl pool refrigerator sept2004 for guarnty 7 year scheme but now refrigerator have not done cooling
check to make sure compressor is running may be something simple like the relay on compressor... also make sure there is no frost build up on back wall of freezer as this would be a defrost issue and will frost up enough that it cannot move air across coil to cool....
repost with any questions....good luck to you...
Jan 08, 2011 | Refrigerators
Hi sir, my whirl pool gets cold in freezer but not ine refrogerator i have checked refrigerant but nothing moves
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Oct 16, 2010 | Refrigerators
Slow water flow
First try a new water filter. If doesn't help, this is often caused by a piercing type saddle valve used to tap into water supply. Try turning it all the way off and on again. If dosn't help, you should replace with a drill type saddle valve. Also try to use copper for water line to unit.
Jun 02, 2010 | Whirlpool ED2FHEXN Side by Side...
The whole unit is making an irritating clicking noise,like a stopwatch.Not continuously but intermittently,sometimes into the night. Very very irritating.
Dear I want to service for my whirl pool refregerator in mohali
please send me contact no of whril pool refrigerator
Mar 26, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
My whirl Pool side by side is not cooling well, I have washed the coils completely and used the recommended thermostat settings, but I have had thawing in the freezer and in the refrigerator,the freezer...
How to check everything
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gold side by side freezer not freezing but fridge is running
Your fan in the freezer is wearing out. When your food in the freezer is blocking the air, the motor is working too hard. After years of using, it needs to be replaced. Get a repair man in to replace with a new parts. My Fridge/Freezer was totally broken and I found this out because the ice was melting. It got fixed and now no problem.
Oct 10, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirl pool gold GD5RHA side by side.
We had the same problem and I AM NOT a repairman. I found that with a lot of freezer door opening, the rubber fill tube, which fills the ice maker tray, had frozen up inside the tube. I had already replaced the ice maker, and still no ice. I am sure a repair person will shudder, but I simple put a Phillips screwdriver up the tube and found the ice was not allowing the tube to refill the tray. CAREFULLY, use the tip of the screwdriver to dislodge the ice and clear the tube. These units do not cool or freeze quickly, therefore keep the doors closed as much as possible and don't let kids stand with the door open while they gaze into the depths while making their decision.
Dec 24, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
235 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
