Timer on oil heater
I have glenair 15 fin oil heater with a timer. I have no manual and would like to know how the timer works.
4 Suggested Answers
  • 4 Answers
SOURCE: honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Posted on Nov 16, 2007
co7196
  • 3433 Answers
SOURCE: vulcan 11 fin coil oil heater. it just stopped working.
The heater should not have been affected by the what the maid had done. Turn off the power to the heater and let set for a bit, Check your thermostar settins, turn all the way dow and back up to what you want set the timer and give it a chance to heat up again. There might be a reset buttun somewhere so look around. I bet its cold in Austrailia right now.. Good luck-Ned
Posted on Jun 12, 2009
  • 18 Answers
SOURCE: Hi, I'm looking for a manual for Oasis oil heater
write model and serial# go on net and look for authorized distributor might even be able to google manuf---and print one out good luck
Posted on Jul 19, 2009
I've got a Heller 10-fin standing oil heater, H-2400T. I would love it if someone can show me where to find the online instruction manual for this. Or just explain how to make the timer function work....
G'Day
I have one of these Heller H-2400T heaters. To operate the timer try this: Plug into power and turn on. Set power control to either Low/Med/High. Set temperature control midway between Low & high.Rotate timer dial to the right to align time of day to the reference point. Ensure all of the red tabs are pulled out. Then push in the ones for the period you want the timer to operate. Works for me. Good luck
Jun 13, 2011 | Heating & Cooling
I have lost the brochure for my heater, the Dimplex Eco 2.4kW 11 Fin Column Heater.how do you set the timer?
Emily, if you live in the USA, contact Dimplex Technical Service 888-346-7539 for that information, as well has getting a replacement Owners Manual.
Apr 18, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
ICE BUILD UP ON BACK FINS IN NORCOLD REFRIGERATOR
A part has failed in the auto defrost system - either the heater is bad, the defrost timer (could be a circuit board or old style timer) or the termination switch (temperature limiting thermostat). If you don't know how to test each one with a multi-meter, call a repairman.
Sep 19, 2009 | Refrigerators
Vulcan 11 fin coil oil heater. it just stopped working.
Jun 12, 2009 | Heating & Cooling
Delonghi TRD0715T heater
turn timer knob clockwise till arrow points to correct time (your time), there are plastic protrusions "ticks"around the knob, they move in and out, move them in for on, and out for off
select time sectors that you wish hearted to heat, each tick is 15 minutes, experiement and become profecient
Oct 27, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
Heater shut off but doesn't turn on by it'self
Do not touch the timer, once you do, it activates it. Set the temp. and leave the timer alone, unless you want it to shut off at a given time, 1 hr. and up. Once the timer shuts off you will have to start it manually.
Oct 14, 2007 | Honeywell HZ-709 Oil Filled Radiator...
Honeywell oil radiator
Set temperature:
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
