Question about Refrigerators
My 4 yrs old maytag french door, bottom freezer refrigerator stopped cooling. Not electrical problem the lights are on but the tempreture control indicates a '_" and it cannot be moved out of it.
I have called a technician, I need nothing more from you.
Posted on May 30, 2009
GE bottom freezer stopped cooling sporadically every 1-2 days then cools again with no intervention. Unit is 5 yrs old.
Put the old board back in. See what it does, from your post, sounds like it was working correctly.
Jan 24, 2015 | GE Profile PGCS1NFZSS 20.7 cu. ft....
I have a Maytag model MFI2568AES french door bottom freezer refrigerator. I have had problems with the control panel not working. We have been able to get ice but could not switch to water. Now i cannot...
don't think you need a new unit . and most of use like the service . the filter does not prevent the ice maker from working . but the water valve does and the tempt in freezer must be 15 deg or lower . ck your fan inside and underneath. both muts be going . hope this helps mm .. and ck with another service theat will be helpfull. mm
Aug 01, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
My Maytag french door, bottom freezer stops cooling. I can hear it humming, the lights are on, but the temp in both continue to climb. We moved everything out,and after several hours, it started working...
It's possible, it may be your high voltage control board, going out. If your model has one of these, it will be located on the outside of the machine, on the back.
Mar 29, 2010 | Maytag MFD2560HES Bottom Freezer French...
My refrigerator won't cool (freezer still working)
The temp sensor is the most likely cause of this problem. However, you have other possible options that you can test and check:
likely the problem with your fridge is a bad dumper control. This is a part which operates with the air flow from the freezer into the fresh food compartment.
The dumper control is located in the in the upper left corner in the fresh food compartment.
Sep 21, 2009 | Maytag MFD2561HE Bottom Freezer French...
UNIT (ABOUT 4 YRS OLD) STOPPED COOLING FREEZER AND FRIDGE AND MAKES A BUZZING NOISE ABOUT EVERY 5 MINUTES.
buzzing noise is possibly the compressor tring to restart. It sounds as if the compressor is going into thermal overload. I would suggest the replacement of the compressor. Good Luck
Dave
Jul 24, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
Maytag Refrigerator
Pull out your WIDE-N-FRESH Deli Drawer at the bottom, and when the lid automatically raises look to the right: you'll find a sliding temperature controller that most likely is all the way up. Slide it down towards the bottom and this will cut back on the cool. Worked for ours!
Jun 04, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerator doesn't cool/freeze - clicking, cyclying noise repeates, but doesn't cool
We had the same thing happen a little while back. The compressor went out and had to be replaced (it was under warranty, but the labor wasn't covered)
May 17, 2009 | Maytag MFD2560HES Bottom Freezer French...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
What is wrong with my Maytag refrigerator
You have a bad high voltage board call the manufacturer, if the unit is under 2 yrs old they may help cover the repair with the problem your having.
Jul 30, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
