Question about HP OfficeJet 7310 All-In-One InkJet Printer
Fix my fax
People snding the fax but the fax is not going truh
  • sweethart Oct 24, 2007
    i can send out but i can not recive fax
    Genius:
  • 1,601 Answers
Introduction Review the information below to determine why faxes cannot be sent or received. Review the symptoms below carefully and then select the symptom that best fits your problem. If the solution links you to a different document that does not resolve the problem, return to this document to continue troubleshooting.
Faxes cannot be received but they can be sent Review the information below to determine why faxes are not being received.
  1. Phone company services: Do you have any of the following telephone line services from your telephone company: Voice Mail, Privacy Block, Security Screen, Anonymous Call Rejection, and Privacy Manager. These phone services are meant to prevent unwanted calls, but they will also stop faxes. Contact your telephone company for their recommended solution for receiving faxes on the same line with these services.
  2. If you wish to receive faxes automatically, verify that automatic answering is enabled on models that have an Auto Answer button, or that the Rings to Answer setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup.
  3. If you have a HP PSC 2200 or an Officejet 6100 that interrupts calls or will not receive faxes, download and install the HP Firmware update for these products.
    1. Visit the HP Support and Drivers Home page .
    2. Select Download drivers and software .
    3. Type in your model number (HP PSC 2210xi for example).
    4. Click the search arrow to the right of the text entry box. You may be asked to select your product from a list of models.
    5. On the software download page, select your Windows version.
    6. Locate and select the firmware update.
    7. Follow the directions to download and install the update.
  4. If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections. For more information on using a TAM or distinctive ring service, go to Using the HP All-in-One and Fax Products with a Telephone Answering Machine (bpu04072).
  5. If you have a PBX phone system, or an ISDN or DSL modem connected to the line, there may be some phone line configuration problems. Fax machines are analog devices and cannot be used on a digital phone service such as those used in many businesses (PBX systems). Install an analog phone line for a fax machine. Refer to document Using an HP All-in-One or Fax Product on a PBX, ISDN, or DSL Phone System (bpu50333) to learn how to correct these problems.
  6. If the problem still exists, continue troubleshooting in the Faxes cannot be sent or received or you're not sure of the problem section below .
Posted on Nov 11, 2007
I want to cancel my Prime Membership but it keeps going to All State Insurance
Hello, It sounds like you have a sypbot or virus, download this and run, it is free:
Internet Security Product Downloads
Pls rate my answer, thk you.
Oct 23, 2015 | Computers & Internet
Oil sending unit 2001 ford taurus
On most engines it is on the driver side of the block under the master cylinder.
Jan 25, 2013 | 2001 Ford Taurus
I have a 2001 chevrolet z71. the air will not blow from the face vents. where might i look for the problem
is it in defrost only check on the passager side under the hood the electric wire that gi truh the fire wall should have a vacumm line it probably disconnect near the engine
Feb 26, 2011 | 2001 Chevrolet Silverado
Nokia N70 message sending fail
hi my nokia n70 is not snding the messages and i hav credit in my cell and is receving the messages.....plsss help me out
Nov 02, 2010 | Nokia N70 Cellular Phone
When i turn on the air conditioner i smell raw gas
the drain tube is block look on the fire wall on passager side you should see a tube that goes truh the fire wall pass a piece of wire in it to unblock itthe water that under the grill will escape there old water stink hope it help fixya our post thank you pierre
Jul 15, 2008 | Pontiac Grand Am Cars & Trucks
Engine quits
block gas filter when you drive gas pressure go truh the filter pack it up less pressure car stall some gas go back ih tank unpack the filter if it would be electrical it wouldnt start (ingniter.or coil) check it out hope it fixya our post thanks pierre
Jul 12, 2008 | 1990 Honda Civic
ABS and Parking Brake Indicator light...
you got a broken wure or bad sensor get the truck pass on a scanner to see the trouble code there no outer way its easyer that way tell me the code i guide you truh it good luck pierre
Jul 12, 2008 | 2001 Chevrolet Blazer
Person on the other end of the line cannot hear me.
try calling a land line no and see if you have the sane prob if you do it is prob a signal problem it might need snding back to manufacture or first you could try unlocking your phone witch you cand do youself self look on net for this as i cant give you name of sit but just use search engine and find a free one then try using your phone on different network you can keep same no if this dont solve problem go back to phone shop and insist it needs repairing i used to work for major repair company this is a common problem usually with the arial it usuallt happens if the phone has een dropped or been sat on and mite have warped the board it can be repaired hope this helps remember rty different network first as they have different network coverage
Oct 30, 2007 | Nokia 6300 Cellular Phone
Fix the fax
Introduction Review the information below to determine why faxes cannot be sent or received. Review the symptoms below carefully and then select the symptom that best fits your problem. If the solution links you to a different document that does not resolve the problem, return to this document to continue troubleshooting. Faxes cannot be received but they can be sent Review the information below to determine why faxes are not being received.
Oct 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Fax
you cant send? or receive?
Here is a troubleshooting guide from HP.
Make sure you follow carefully.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02151&cc=us&lc=en&dlc=en&product=391182&dlc=en&lang=en
HP OfficeJet 7310 All-In-One InkJet Printer Logo
274 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
