Question about Garden
I need some specs and instrucion on how to use it
I am looking for some instructions and specifications for a Gerni 2200 diesel powered hot water pressure washer, can you help
  • 174 Answers
SOURCE: How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Posted on Aug 26, 2009
  • 691 Answers
SOURCE: Craftsman Pressure washer will not spray
your not missing anything, check the pump, they tend to go bad over time and may need replacing. The pump provides the pressure as well as the suction for the whole process, pulling water from the hose or tank and pushing it forcefully through the pressure washer line. If the motor is running and you have the water going through the line and to the pump, and no water is coming out, my guess would be the pump.
Posted on Sep 24, 2009
mkh5094
  • 145 Answers
SOURCE: Oil
Remember when your searching for something you can't find the internet is always your best bet. You should also use a good search engine; www.bing.com is one of the best search engines I have ever used. I searched some stores that have the oil your looking for, one online store is www.amazon.com and if you have one near you and they also carry it at Sears. The grade of the oil is definitely weird, 75W90. Also if you would like to look for other stores that carry it go to Bing and type "Briggs & Stratton Pressure Washer Oil" into the search bar.
Posted on May 23, 2010
jgwhomeequip
  • 1902 Answers
SOURCE: No water pressure coming from pump
The pump is bad and needs to be replaced. you have done all the test. On the Briggs they do have kits to rebuild the pump on your system you can just go to there website and get the rebuild kit. It is safer to go through them because they have jsut started producing the rebuild kits, and other companies have tried to copy them, but there kits are worthless. Please rate
Posted on Jun 04, 2010
SOURCE: troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Posted on Jun 08, 2010
4610 ford diesel tractor water pump bolt torque settings
First you need to know the diameter of the bolts and the type of thread ie 3/8 N/C or 5/16 N/F then look at the type of bolt ie plain steel or high tensile SAE grade 3, 4, or 6, once you know this go to a general purpose bolt torque chart, and derive the torque spec info.
If the water pump is cast iron use the full torque specification.
If the water pump is alloy then reduce the torque spec 10%
Below is an example of a general purpose bolt / nut torque chart
May 05, 2016 | Ford Cars & Trucks
Loud humming/buzzing sound when the washing cycle starts. It does it only with cycles with hot water from above 60C and above.
hi
I suggest that if the machine does have a hot fill intake that you connect this because this will insure long life to the electric element you will be saving money as you already have hot water and this might rectify the problem
Jan 28, 2018 | Washing Machines
Which size of feeler gauge do we use for td42 valve tappet clearance
the engine make would be a help but generally if it is petrol ,water cooled --.010" hot inlet and .012" hot exhaust
if diesel then .012" inlet hot and .014" exhaust hot
if air cooled petrol then same as for diesel
best if you get a workshop manual and check for specifics.
Jun 08, 2015 | Cars & Trucks
Cyl head torque specs
go google --type in torque specifications for toyota ( your vehicle ) diesel. There are pages that will give the specs and the rotation to do the job.
Jun 27, 2014 | 2005 Toyota LandCruiser Prado
PCV-2200
Remove the PSU use the Model number to "Google" a replacement. You can use more watts, but stay with the same type and output power specs. This may help: http://www.docs.sony.com/release/PCVRS100_SR.pdf ALSO, take a look at Sony Support: http://esupport.sony.com/perl/select-system.pl?PRODTYPE=1
Feb 22, 2013 | Computers & Internet
Gerni 2200 instruction maunal
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.
Apr 28, 2012 | Computers & Internet
I have smoth's hot water tank. problem is pilot lite is off. how do u turn it on?
You have tank-type gas water heater with standing pilot light.
Instructions for lighting pilot light are usually on front of water heater.
Since water heaters vary widely, if you want specific information without guessing, then add a comment with model number that appears on label on side of tank, and also describe the gas control valve on front of unit.
This information will let expert located manual and look up specific information plus troubleshoot steps for that model.
Aug 24, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
I was just given an Element Electronics FLX-3711B 37" wide screen tv but there is no power supply. Is it a specific power supply or will a computers power cord work since they have the same style...
you will need the power specs of each unit, look on the tv and computer near where they plug in, should be tagged right there or somewhere close. by law it has to be tagged. if not right there keep looking . and yes it is specific.
Mar 13, 2011 | Element Electronics FLX3711B 37 in. LCD TV
Need a power cord unit has no specs for amps/volts
Adaptec web site returns the following...
The replacement power supply must meet these specifications:
5 Volt DC Output with at least 2.5 Amperes capacity. The DC connector is configured with positive (+) on the internal or center lead and negative (-) on the external.
If you've found this reply to be a solution to your problem then please take time to rate this post. - Thanks.
Jun 28, 2009 | Adaptec AVC-2200 (avc-2210) Video Capture
Cuisinart Coffee Maker DCC 2200
The user manual is a free pdf download from the cuisinart web site.
Dec 26, 2007 | Cuisinart DCC-1200 Coffee Maker
Garden Logo
336 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
