Question about Dryers
The timer is not working and the dryer is not getting any heat.
The timer is not working and thedryer is getting no heat.
  • irish2atee20 May 30, 2009
    It is a gas dryer and the model number is 11076722695
    Is it possible that there is a safety feature built into a malfuctioning timer control that won't allow for heat to be produced?
    President:
  • 1,136 Answers
HI, If you are using the automatic cycle, it will not advance when the dryer is not heating.
Could I get the model # so I can assist you further?
I need to know if it is electric or gas .
Thanks
Vic
Posted on May 30, 2009
  • Victor
    Victor May 30, 2009
    I don't believe it is a timer issue.
    Remove the little cap on the front lower panel and turn the dryer on to heat. Look inside the hole you uncovered and see if the ignitor glows. If it glows but there is no flame before the ignitor shuts off, change the coils on top the gas valve. Here is the istruction for this:
    UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
    If it does not glow, follow these instructions:
    UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
    Please let me know if this help or if I can assist you further.
    Vic
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Gas dryer dries sporadically. dial for automatic dry doesn't move
? 5:51
Although electric dryers are the simplest appliance to work on, ...Replaced outlet, cord, and moved the outlet so we don't have the same ... Whirlpool LER4634EQ0 110 v timer motor, when timer contacts TM .... David Villa 7 months ago ... 3 years and now thedryer won't heat and the timer doesn't advance, ...Missing: cu
Nov 17, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
Dryer wont stay lit
if the flame is liting most likely problem is bad air movement.go outside with thedryer running and check the hood to see how strong the air is blowing out,if there's a cage or anything blocking the hood remove it,if the vent line is a long run remove the vent line from the back of the dryer,stick a leaf blower into it and blow out the lint to the outside.also with the dryer unplugged,remove the bottom panel,remove the lint filter and metal duct the filter slides into,clean that out and blow out the blower wheel with a shop vac,you can blow out the gas tube where the flame ignites to make sure it's clean blow off the motor and the cabinet and vac up all lint that blows forwards.you can try running the dryer with the vent line removed to see if it runs any better.when the dryer first heats up the flame will come on until the temp. is reached and it will shut down,one more thing to check,when gas coils start to fail you'll have heat for like the first 15 to 30 minutes,then when the coils heat up the ignitor will glow but no flame,after the coils cool down they will work again.how are you running it on timed dry or more or less dry,if you run it on auto or more or less dry there's a sensor inside where the lint filter is,try cleaning it up or try running it on timed dry to see if it runs any different,when on auto the heat comes on,when it reaches temp. the heat stops and the timer will advance,when it calls for heat the timer stops and the heat comes back on,it will do this until the clothes are dry.your model has an even heat board in it that can also cause problems but if the flame is liting it sounds like you have a block somewhere.go here this will tell you a little more about your model dryer.
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
May 23, 2013 | Dryers
When i turn on thedryer it will run but will not heat up. it is a DLG5988B Gas Dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 24, 2011 | Dryers
My whirlpool ultracare !! dryer will not heat. I have to dry things over and oer and over til they finally dry.
i looked up your model number and that's to a washer not a dryer.if it's a gas dryer it sounds like you have bad gas coils located on top of the gas valve.the coils work until they heat up like in the first 15 to 30 minutes and they shut down,when they cool they work again until they heat up and fail,this is why you have to keep running thedryer,one more problem could be the dryer needs to be cleaned out.clean out the vent line,clean out the duct that the lint filter slides into and vac out the cabinet where the motor is
Jan 22, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Thedryer is not getting hot
Most likely you blew a thermal fuse, and usually that is caused by a bad high limit thermostat. The thermostat sticks and it gets too hot then the fuse blows. They come as a kit. They're not too hard to replace. Unplug it and take the back off. The two parts are on the side of the heater box located on the right side facing the back if memory serves me. Good luck.
Apr 26, 2010 | Kenmore 98702 Stacked Washer/Dryer
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
My dryer will not heat and timer works until the cooling stage
It's either the timer or insufficient air flow. check your vents to see if sufficient air is coming out.
Jul 07, 2009 | Dryers
When dryer cycle is done elements stay on
One of the switches that controls the heating element has not closed.
Apr 30, 2009 | Frigidaire Dryers
Dryers Logo
100 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
