Question about Raymarine C80 GPS Receiver
No fixed postion has ? over gps icon in upper right corner of unit
Have c80 can't get fix on gps radar works no chart
    Problem Solver:
  • 12 Answers
Touch lower right hand corner and see if it reboots software. will probably lose all info saved
Posted on May 30, 2009
My Raymarine C80 CHart plotter won't load.
Check to see if this is a power issue by connecting to shore power and fully charging your batteries overnight with instruments off. While still connected to shore power, with batteries fully charged, turn on C80 navigation system. If the loading screen comes on and does not reset, then try holding down the button immediately to the right of the red power button for at least 3 seconds to see if the system re-boots.
Apr 13, 2010 | Raymarine C80 GPS Receiver
C80 GPS
Please remove the power cable form the unit and wait for 30 min then replug it switch on ,,let me if your facing the same problem again...............
Jul 07, 2008 | Raymarine C80 GPS Receiver
Connect Ratheon RL 70 to Raymarine E80
The two devices can share Nav data only. No radar, Sonar or Chart will be shared.
Hook the RL70 and the E80 together on SeaTalk and all data will be shared both ways. Alternatively, it could be done with NMEA 0183, which is directional, or you could also translate the RL70 data to NMEA 2000 and share it that way. As long as you have all Raymarine equipment, you are home free using a three wire Seatalk connection, with only two hooked up, Yellow and Bare, color to color.
Remember, this will share Nav Data only.
Nov 14, 2009 | Raymarine C80 GPS Receiver
Boat on screen does not point the direction the boat is going e-80 series also chart will not go course up or heading up like the radar does unit is set in relative motion mode
The direction of the boat symbol is depending on the compass course from the autopilot. You will see that your GPS course (COG) and magnetig heading on the autopilot differs. Solution is to calibrate autopilot compass. Will advice you to not use course up, stick to north up or heading up.
Sep 08, 2009 | Raymarine C80 GPS Receiver
Scanner not reponding - Checking HW
1.try with a new software 4.29
if you have an old one like 2.14 you have a problem.
2. After this try you C 80 on a nother boat or Raymarine dealer
than you will know if the C 80 works
Jun 20, 2009 | Raymarine C80 GPS Receiver
C80 display is locked up
When turn on the power on the switchpanel immidietly
press the first grey bottem near the powerbottom so long till it shows you factoryreset after this look wich software you have it shoud be 4.29.
if not use a CF card to install .
Apr 26, 2009 | Raymarine C80 GPS Receiver
Scanner self test result...is display comms/fail /raymarine c80 18" dome
Chances are that your scanner cable may be bad. Check inside the dome and make sure that the little wires going into the black connector from the radar cable are seated correctly and all the way in. This can cause tons of problems. Also check to make sure that your pins in the back of you unit are not corroded or broken off.
Jul 24, 2008 | Raymarine C80 GPS Receiver
Raymarine G series radar
Your problem is likely noise from the motor. Modern diesels use high speed networks, so it could be interference. Next likelihood would be a software issue. Is the diesel set up to display info on the G display?
Solution could be re routing cables, grounding or un grounding devices. First step is to send your processor to Raymarine, sorry, necessary step to eliminate hardware failure. This is a tough symptom, so do the easy stuff first.
Jun 16, 2008 | Raymarine C80 GPS Receiver
Raytheon rl70
I've had the same problem. before replacing the antenna, try to reset the antenna by removing power to the Raystar 120. Disconnect power by either turning off all batteries or disconnecting the red wire from the antenna at the point where it enters the junction box for the chartplotter. This action effectively removes all memory from the antenna and resets it to factory settings. There is a lithianium battery in GPS antenna that holds memory data in the antenna. Disconnecting the power to the antenna for a few seconds clears the memory.
This is exactly what I did and when I turned the chartplotter back on, my Raystar 120 immediately began working again.
May 05, 2008 | Raymarine RL70CRC GPS Receiver
Gps mapping
It sounds like you are reporting that the GPS is not getting a fix?
What color light are you seeing on the GPS receiver? We are hoping for a green light indicating it has a fix. Any color at all indicated it has power. If there is no light on the receiver, there is no power being fed to it.
Depending on how this was installed you could get power from the C80 itself, or from the larger SeaTalk network if you have instruments and autopilots. MAke sure all of your breakers and switches onboard are powered on to start. The GPS receiver could have been wired to a different circuit than the display.
Sep 17, 2007 | Raymarine C80 GPS Receiver
Raymarine C80 GPS Receiver Logo
347 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
