Question about Smith Corona Office Equipment & Supplies
The i seems stuck on Smith Corona
When I turn on the typewriter the i just keeps printing over and over like someone is holding it down. If I try to type another letter it will type that one but then the i lever is still up and making noise.
    Champion:
  • 204 Answers
Sound like a small spring is off the typebar cam.If you move the I by hand you may be able to see if the spring os off or there is a bind in the typebar. This will also cause repesating
Hope this helps,
Squipps
Posted on Oct 08, 2009
My Brother ML100 is not printing what I type
Hammer sticking and typing incorrect letters (and or skipping letters): 1) make sure daisy wheel installed correctly. 2) hold down CODE key & Q (RESET) to reset wheel...if still not corrected 3) WD40 the hammer at the base & joints where moving parts are, keep typing until oil seeps in (this last one fixed it for me)
Typing light and inconsistant-top part of letter okay but bottom too light or not there: to left of hammer (at base) are 2 screws, I losened them and adjusted hammer to different forward and backward spots..finally found the ideal location where full letter printed and had the correct force it needed to print correctly.
Feb 21, 2013 | Brother ML-100 Typewriter
When you type, each character you strike actually types another letter.
first try turn typewriter off, (button on left panel toward the back), then turn it back on, and while hold down the CODE button, press RESET key, the whole print head will move and reset
if that doesn't work, power off again, open the cover, release the lever to the Daisy Wheel, and inspect that Daisy Wheel - mine has a bent forward letter, and another letter was kinda stuck to the side of another letter... I gently fix both letters, put the Daisy Wheel back in, firmly lock it in place with the lever, close the cover... and voila, it works like a charm.
While you have it open you might want to dust (use the cleaning spray can duster)... You wouldn't believe what I found in my typewriter... Good luck!
If that doesn't work, I would replace the Daisy Wheel.
gkt
Jan 12, 2011 | Brother GX-6750 Typewriter
When typing does not print whole letter or doesn't print at all.
it would help if i knew exactly what model # we are talking about. but try this. look closely at your ribbon film after you type some characters. are the letters overlapping themselves? if so, press and hold the "code" key down while pressing the period key. let up and try typing. if that doesn't help, write back with model # and maybe i can assist further.
razors
Mar 30, 2009 | Swintec Office Equipment & Supplies
When i turn it on it will beep every letter i enter but won't type anything it is a swintec model-600
try putting the machine in test mode. You can do this by holding down the margin release key while turning it on. Keep holding it down until it starts typing by itself. Then turn it off and on again and see if it works.
Mar 07, 2009 | Swintec 7040 Typewriter
Typing in jibberish when i type a letter
Hold down the CODE key and the "L" key (says 'lang' underneath the "L")
Feb 16, 2009 | Brother SX-4000 Typewriter
Space between letters
fined the key that has expand printed over it. hold down the code key and press the expand key. will turn this function off.
Jan 05, 2009 | Brother ML-100 Typewriter
Margin Release
Try holding down on the MR (margin release) key and turn on. Machine will print a few lines with all the letters. Turn off and then on and try. Also make sure someone has not switched the key tops for left marging and right margin, I have seen this "joke" played on people. Can you set either margins?
Aug 13, 2008 | Nakajima AE-710 Typewriter
Wong letters & numbers
I downloaded the manual from http://www.devicemanuals.com/downloadguide.php and then, following the instructions there, I removed then re-inserted the daisy wheel. This solved my problem. Perhaps it had somehow gotten out of adjustment. At least, it is something to try if you haven't tried it already.
Jul 15, 2008 | Brother GX-6750 Typewriter
Delay print
I found the answer to this situation: To turn off delay print function, Push the print mode button on the upper right hand control keyboard.
Thanks for the help!
Kathy
Nov 26, 2007 | IBM Wheelwriter 30 Typewriter
46 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Jim Goldsmith
Jim Goldsmith
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
