Question about Sony KP-51HW40 51" Rear Projection Television
Remove Speaker Grille from Sony KP-65WV700
I just sent this question via your $14.99 service.  No reply yet, so, while I'm waiting...
This procedure:
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
seems likely to be what I can use to solve my Sony KP-65WV700's too-much blue, and wavy-blue line problem.  However, the front speaker is attached differently from the one described here.
Can you describe how to remove the speaker grille from my TV?
After I remove the six screws on the right and left back, and lightly pull on the grille plastic piece, it appears to be attached to the upper, screen piece above it, at about 6 or so inches from the right and left sides.
  • com88cet May 31, 2009
    Thanks for the reply!  So far your reply is the most specific I've heard.
    After removing the screws, it barely moves at all.  I can peel up the right and left sides a few millimeters, but that's about all.  Obviously, I don't want to risk breaking it.  So it doesn't feel like it's attached by wires in the same sense as what I saw in the pictures in http://www.somelifeblog.com/2007/06/sony...
    It's still quite firmly attached, and again, the attachment point appears to be about 6 inches in from the two sides toward the top.  When I pull on the bottom right side, it moves out a bit, but when I pull on the top right side, it doesn't move very much, and past that 6-inch-in point, I can see it moving in a little, as if it were pivoting on that point.
  • com88cet Jun 23, 2009
    Back to this again...
    Could I Email to you, or somebody, a photograph of the problem with removing the front grille?
    I removed the back panel of the TV, and I can clearly see the box that has the three potentiometers (well, 6 actually, but 3 of interest) described in http://www.somelifeblog.com/2007/06/sony...  So I'm pretty confident that, if I can just get the speaker grille off, I could fix the problem.
    My KP-65WV700 (http://di1.shopping.com/images1/pi/5d/5a...) is clearly very similar with the KP-51HW4 described in that link, but it's speaker grille is different, and is attached differently.
    New Friend:
  • 37 Answers
So you got the six screws undone, great! Now you can pop off the front speaker grill. The easiest way is to work your hand along the top and bottom to pop the plastic out of the "holders"
If what you are describing to me is the main wires still attached to the rest of the TV. So don't pull it out too far! If you do it right you won't have to unplug the wires, and save yourself some hassle... with this TV you'll have to pull it out JUST ENOUGH to get access to the carboard/masonite backing, removing such will give you full access to the six controls.
Adjust from there! Sorry for the wait, and I hope this helped out!
Posted on May 31, 2009
  • fraywing
    fraywing May 31, 2009
    Interesting, and you definitely don't want to do damage your TV. Is it under warrany still? Perhaps you could try and slide the panel out, rather than pulling it out directly? If it is attached to the top, pulling on it would definitely be a bad move. Perhaps if you attempted to lean it back, and slide the grill downwards instead of outwards? I'm sorry you are having such a difficult time.
Kp-65wv700 7 blinks
hello High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
shaun
Nov 10, 2009 | Sony KP-65WS500 65" Rear Projection...
Kp-65wv700
You need to adjust Green screen drive control your green tube could be shorting out.
Sep 14, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Blue gun control
Remove the front speaker grille and also the smal;l access panel and you will see a small control box with 6 switches 3 control the focous and 3 control the screen control. The screen control will be laid out like the CRTs are Green in the center and blue and red on either side just turn the blue down very little or you will make the CRTs shut down.
May 01, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Sony kp-65wv700
take the back off there should be a small rectangle with 6 buttons on it 3 for focus and 3 for the G2 (screens) some models have this control in the front behind the speaker grille behind an access panel and others have the control switch on the circuit board that is attav=ched to the crt neck. Either way its just a small switch much like a volume switch but smaller. Depending on what chassis you have it will be in one of the 3 areas I have mentioned. just turn it down a little. If that doesnt take the lines away you will need to trouble shoot the blue drive circuit.
Mar 21, 2008 | Televison & Video
Sony kp-65wv700
I sent instructions in my last post to you, if you cant find it let me know and I will pull up the specific model for your set and try to help you locate it. And thanks I enjoy helping people with their sets I have been doing this over 25 years and still enjoy working with electronics.
Mar 21, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Blue Screen
You have a bad blue picture tube. If you replace it the red and green will be weak and probably go sooner than you think. Everytime I had to replace a tube in a sony projo tv i had to replace all 3 picture tubes at the same time. It's very expensive if you don't have any type of warranty coverage.
C-Dog
Feb 10, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Sony Kp-65wv700 Too much red -- white looks redish
fix the red:
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Nov 01, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Sony KP-51HW40 51" Rear Projection Television Logo
631 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
