Question about Malber TD800 Electric Dryer
Malber Dryer won't start (sine-wave light flashing)
We just moved into an apartment with Malber TD800 dryer and P21 washer. I can't figure out how to use these things and they're are no manuals online. Right now I have wet clothes in the dryer. When I hit the on/off button the green "sine-wave" light blinks. I think this it the "working" light and the blinking indicates some problem. I've emptied the condenser resivoir and cleaned all the filters. Anyone know how this thing works?
  • haljones696 Aug 10, 2009
    Thanks BigBalla! Do you know what the 1100/500 button on the washer is? Load size?
  • Kathleen DUNN Jul 30, 2012
    Where is the zero? I don't know what any of the symbols mean without the manual.
The dryer is easy: turn it on and turn the control to 0. It will beep. Then turn it to the desired program (20, 40, 60 minutes or a pre-programmed cycle), it will beep again and start. If there's a red light you have to empty the water tank at the front on the left. The washer is a normal washer. Just pick your program and press start (be patient as it takes a while to get cranking). Sometimes you have to really push the door closed very hard. Try and turn the control to 12 o'clock before setting it again.
Posted on Aug 10, 2009
Where in florida can I get a malber p21 washer and get the dementions of it. I have one in NY and love it
A Malber P21 has the following dimensions:
Height:33 1/2"
Width:23 1/2"
Depth:20 7/8"
(From the AJ Madison Web Site)
The model is discontinued, though.
http://www.ajmadison.com/cgi-bin/ajmadison/P21.html
The current model is the P31.
It's an Italian model sold primarily in the New York area.
You may want to call Malber at 516.323.5299. or email INFO@MALBERAPPLIANCE.COM.
Oct 17, 2014 | Malber P21 Front Load Washer
Does not turn on
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 25, 2010 | Malber TD800 Electric Dryer
My Malber TD800 Dryer runs but will not heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
rrtrt
Aug 22, 2009 | Malber WD1000 Front Load Washer/Dryer
How to install a new dryer belt in a newer moffat dryer
how do i install a belt on my moffat dryer model # ruxr453ev1ww
Jun 27, 2009 | Malber P21 Front Load Washer
Malber td 700
need to no where to get belt for malber td 700?
Mar 05, 2009 | Malber TD700 Electric Dryer
Malber P21 works 3 times slower than normal; I am afraid it will just stop.
I have a Malber P21 the door was open and not turned on and it filled with water till it overflowed onto floor....any ideas?
Dec 02, 2008 | Malber P21 Front Load Washer
Malber WD 1000 dryer help...
jack it should start turning after a while as soon as the dryer has warmed up.
Does it dry however?
Jul 21, 2008 | Malber WD1000 Front Load Washer/Dryer
Malber TD800 Electric Dryer Logo
417 people viewed this question
Top Malber Dryers Experts
Charles T Nevin
Charles T Nevin
Tim Whalen
Justin Duby
Justin Duby
Are you a Malber Dryer Expert? Answer questions, earn points and help others
