Question about HP OfficeJet 7310 All-In-One InkJet Printer
Fix the fax
1.first wie had the problem.wen the phone would ring after two ring the fax would pick up even wenn the phone and the fax hadet two different ring,so truh the technical support i was ebal to fix that ,but after i fix ring it is adifferent problem ,wenn the fax is ging it not going truh -so people sending the fax bat i no recev it,so help mi please,
    Genius:
  • 1,601 Answers
Introduction Review the information below to determine why faxes cannot be sent or received. Review the symptoms below carefully and then select the symptom that best fits your problem. If the solution links you to a different document that does not resolve the problem, return to this document to continue troubleshooting.
Faxes cannot be received but they can be sent Review the information below to determine why faxes are not being received.
  1. Phone company services: Do you have any of the following telephone line services from your telephone company: Voice Mail, Privacy Block, Security Screen, Anonymous Call Rejection, and Privacy Manager. These phone services are meant to prevent unwanted calls, but they will also stop faxes. Contact your telephone company for their recommended solution for receiving faxes on the same line with these services.
  2. If you wish to receive faxes automatically, verify that automatic answering is enabled on models that have an Auto Answer button, or that the Rings to Answer setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup.
  3. If you have a HP PSC 2200 or an Officejet 6100 that interrupts calls or will not receive faxes, download and install the HP Firmware update for these products.
    1. Visit the HP Support and Drivers Home page .
    2. Select Download drivers and software .
    3. Type in your model number (HP PSC 2210xi for example).
    4. Click the search arrow to the right of the text entry box. You may be asked to select your product from a list of models.
    5. On the software download page, select your Windows version.
    6. Locate and select the firmware update.
    7. Follow the directions to download and install the update.
  4. If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections. For more information on using a TAM or distinctive ring service, go to Using the HP All-in-One and Fax Products with a Telephone Answering Machine (bpu04072).
  5. If you have a PBX phone system, or an ISDN or DSL modem connected to the line, there may be some phone line configuration problems. Fax machines are analog devices and cannot be used on a digital phone service such as those used in many businesses (PBX systems). Install an analog phone line for a fax machine. Refer to document Using an HP All-in-One or Fax Product on a PBX, ISDN, or DSL Phone System (bpu50333) to learn how to correct these problems.
  6. If the problem still exists, continue troubleshooting in the Faxes cannot be sent or received or you're not sure of the problem section below .
Posted on Nov 11, 2007
Hooking up fax to KX TG7871 Panasonic Phone
There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
Need model number of your fax - google that!
Service manual for your phone.
http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00059780#Dist_ring
Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
  1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
  2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
Mar 06, 2014 | Lands Phones
Hello wie kann ich handy mit PC verbinden.was muss ich herunterladen?
1. Klicken Sie HIER. Dadurch werden Sie auf der Samsung Webseite Kies bringen.
2. Wenn auf dieser Seite, Blick auf die Links f?r die genaue Modellbezeichnung Telefon.
3. Klicken Sie auf diesen Link und laden Sie die Kies-Programm.
4. Nach dem Herunterladen Kies, f?hren Sie die heruntergeladene Datei und installieren Sie das Programm Kies.
5. Jetzt in der Galaxy S-Stecker an Ihren PC mit einem Mikro USB-Kabel (in der Regel mit dem Handy im Lieferumfang enthalten)
6. Die Kies-Programm wird automatisch gestartet, wenn das Telefon angeschlossen ist, oder Sie k?nnen den Kies Programm zuerst.
7. Sie werden in der linken oberen Ecke, dass es eine Verbindung herstellt zu sehen. Dann werden Sie M?glichkeiten, wie und was man zu synchronisieren wie angegeben werden.
May 04, 2011 | Samsung Galaxy S GTI9000 Smartphone
Meine linse ist kaput wie kann ich sie raparieren
Ich denke nicht, du kannst. Zugriff auf das UMD-Laser erfordert in der Regel unter das Ganze auseinander. Es ist riskant, und es nicht wert. Schicken Sie es zurück zu Sony, wenn es noch unter Garantie. Wenn nicht, können Sie versuchen, Custom Firmware auf der PSP setzen, aber darauf achten, dass die PSP kann es erste Handgriff, wie man es permanent zu brechen, wenn es nicht ist. Nachdem wir Custom Firmware drauf haben, können Sie Spiele auf Ihrem Speicher-Stick laden und spielen Sie sie direkt aus dem Stick gratis. Sorry, wenn es irgendwelche übersetzungsfehler, ist Deutsch nicht meine Muttersprache.
Feb 18, 2011 | Sony PlayStation Portable (PSP) Console
I don't use an answering machine. My phone has voice mail but the machine is not even recognizing when a fax comes in. The fax call goes into the voice mail each time. The phone line is working-I get a...
You need to set your phone to pick up later than the fax machine. set it to pick up on the 4th or 5th ring, set the fax to pick up at 2 or 3. Better yet, get a distintive ring # set up by your phone co. then the fax will only recognize that ring.
Dec 30, 2010 | Canon PIXMA MX870 Wireless Office...
Hallo, meine Camera wie oben funktioniert nur noch wenn keine Speicher- karte im Gerät ist. Mit Speicherkarte ist kein Strom vorhanden. Wo ist hier das Problem. Habe kein Geld für teure...
Ich bitte um Entschuldigung, aber ich bin mit Google übersetzer. Bitte schauen Sie in Ihrer Kamera CF-Karten-Slot. Ich vermute, dass Sie eine gebogene Nadel in es haben kann. Wenn ja, entfernen Sie die Batterien und Karte. Verwenden Sie einen kleinen / dünnen Juwelier flachen Schraubenzieher, bis die Nadel verbiegen wieder so nah wie möglich. Eine preiswerte Juwelier Schraubenzieher funktioniert problemlos. Ein weiteres Tool, benutze ich manchmal ist ein steifer Draht mit einem gebogenen Haken am Ende. Dies trägt dazu bei sehr flachen Pins erhalten begonnen. Nehmen Sie sich Zeit und verbrauchen viel Geduld (machen Sie eine Pause dazwischen, wenn nötig). Macht einfach weiter es nach oben und gerader einer "kleinen Menge zu einer Zeit". Was immer Sie tun, versuchen Sie nicht, um es mit einem Tastendruck entspannen, werden Sie nicht in der Lage, es zu tun.
Es muss nicht perfekt sein, nur so nah wie man es bekommen kann. Wenn es das Beste, was Sie es bekommen können, nehmen Sie Ihre Flash-Karte und "langsam" einfügen. Die Karte selbst ist fein-align des Stiftes. Entfernen Sie die Karte, und stellen Sie sicher, dass die PIN noch gerade ist. Wenn ja, setzen Sie die Karte und versuchen, die Kamera.
Nov 17, 2009 | Canon PowerShot A85 Digital Camera
Need to set up phone/fax instead of just fax
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
Answering machine will not pickup calls.
set machine to duet mode it will know then the difference i think canon also call it net switching
Regards
Canon tech
Apr 01, 2009 | Brother MFC-7220 All-In-One Laser Printer
Ich habe einen speedport W721V und weiss nicht wie ich µorrent zum laufen bekomme
Kommt darauf an was du meinst damit, daß es "nicht lauft". Am unteren Rand des Fensters von µtorrent sieht man in der Mitte der Statusanzeige einen farbigen Punkt. Wenn dieser ROT ist, hast du wahrscheinlich ein NAT-Problem (vorausgesetzt, du hast deinen Port in deiner Firewall freigegeben. Wenn noch nicht, dann solltest du es jetzt tun. Wähle einen Port im Bereich zwischen 49152 und 65535, der ist nämlich bestimmt frei).
Meistens kommen NAT-Probleme daher, weil der Router den Verkehr für unautorisierte Ports blockiert; das ist eine Sicherheitseinstellung, kann aber auch mit normalen Datenverkehr Probleme machen. Neuere Router haben oftmals die Unterstützung des UPnP Protokolls eingebaut. Schau dafür in deiner Routerdokumentation nach, wie du diese Funktion im Router aktivieren kannst. Danach setze in µtorrent unter: "Optionen" "Einstellungen" "Verbindung" "Aktiviere UPnP Port Mapping" einen Haken. Das farbige Symbol (NAT-Anzeige) sollte von gelb auf grün wechseln, sobald du erstmals eine eingehende Verbindung hast (natürlich wenn du einen torrent laufen hast!). Wenn es aber rot wird, oder du im Reiter "Protokoll" eine UPnP-Fehlermeldung erhältst, dann schalte UPnP ab und leite deinen Port manuell weiter. Sollte das nötig sein musst du den Empfangsport für µtorrent einstellen. Dafür unter "Optionen" "Einstellungen" "Verbindung": einmal auf den Knopf "Zufälliger Port" klicken, und notiere dir den vorgeschlagenen Port. Diesen Port musst du jetzt in deinem Router weiterleiten (forwarden). Du kannst aber auch einen Port deiner Wahl verwenden. Jetzt den Haken bei "Bei jedem Start von µtorrent einen zufälligen Port wählen" rausnehmen. Damit bleibt der Port immer gleich. Wie gesagt, idealerweise steht bei deinem Port z.B. '34250-34377 Unassigned' (wenn du z.B. den Port 34343 gewählt hast). Das sollte es sein, wenn du noch Hilfe brauchst lass es mir wissen.
Wenn diese Lösung geholfen hatt, bitte klicke auf RATE :)
Jan 28, 2009 | Computers & Internet
Fixsing the fax
just disable the auto answer feature in your all in one printer setup .it may be happen bcoz you set as fax recevive function after 2 or 3 rings so just chage it. bye
Sep 28, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Fax ring tone or ring leader
im sorry to say the machine you have does not have DRD distinctive ring detect.
Jan 21, 2007 | Panasonic Workio DP-2330 Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
146 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
