Question about HP Deskjet F4180 All-in-One InkJet Printer
Hp F4180 No copy to Plain paper
HP F4180 will not make copies if the paper type is set to Plain paper. It goes through the motions but he paper comes out almost blank. A grey box from the original consistantly copies but nothing else. The printer copies perfectly if the paper type is set to Photo paper. It also scans and prints perfectly in both Black and color.
  • douglasharri Jun 02, 2009
    That might all make sense if the printer didn't print black either, but it prints in both black and color fine. It even copies black. It's just really slow when it does it since I must scan and copy to photo paper which is apparently hugher resolution.
If you just replaced the ink cartridges, make sure you've removed the plastic tabs that cover where the ink shoots out. If they are old cartridges, make sure that the nozles haven't dried up. Remove the cartridges and dab a cloth (one you don't mind staining) where the ink shoots out, if all the colours show up, it's clear. If you notice very little colour, or none at all, try dampening the cloth and wiping down the cartridges to promote inkflow through the nozles. Hope this helps.
Posted on Jun 02, 2009
On button steady e on display paper type plain
Remove the Cartridges,
Clean the contacts on Cartridges and inside Cartridge slot ( electrical contacts )
Install the Cartridges back into Cartridge slot
If that does not stop giving the "E" -
Disconnect the Power cord from bak of printer
Press and hold the Cancel and Plain paper type button and connect the cord holding the buttons.
Release the buttons after 3 seconds
If should go thru alignment process
Jun 22, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
No print on copies or faxes
This is a clogged print head. This happens if the printer has been off for a long time or if the cartridge was removed and the unit left empty for any time.
Take out the cartridge and press the print part on a piece of paper. Any black lines? If not, you will need a new cartridge. Wiping the print head gently with a Q-tip moistened with PURE alcohol (99%) may restore printing.
Mar 31, 2010 | HP 1040 Plain Paper Inkjet Fax
Photosmart 3110 xi copy problem - says ''paper size not supported. Copy cancelled.'' any size paper causes this response. What can I do to fix it?
Press the copy menu on the printer.
select copy paper size that you are using.
Then select copy paper type as plain paper.
Then press Ok.
Try copy.
Mar 14, 2010 | HP Office Equipment & Supplies
920c is printing very slow, like 1 copy in 5
it is possible that your printer settings is set print high quality for a photo paper. try to check if you are printing on plain paper, select paper type as plain paper and quality to normal.
Nov 06, 2009 | HP DeskJet 920c InkJet Printer
Hp Photosmart C4100 series (copy 6) printer missing!
Uninstall all those printers first. restart the computer and reinstall the drivers again.
May 25, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Hp1040 fax and copy machine
I solved this problem by returning my fax machine to where I purchased it and exchanged it for another type of hp machine and it automatically goes in long format when it scans long format paper. If it scans short letter form, it automatically copies itself and adjusts itself. Thank you aniway, durl
Nov 25, 2008 | HP 1040 Plain Paper Inkjet Fax
HP 2710 Printer
Issue When using colored paper in the all-in-one, printing or copying is slow. Solution This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode. Follow the steps below to temporarily change the Automatic Paper Type setting from within the application that you are printing from.
  1. Click File , then Print or Print Setup .
  2. Select the appropriate all-in-one from the drop-down list and click Properties .
  3. Click the Paper/Quality tab and under Type is: select Plain Paper . Changes made within the application might not be permanent and the setting will default back to Automatic after closing the application. The setting will have to be changed each time colored paper is used in the all-in-one.
Follow the steps below to change the default Automatic Paper Type setting to plain paper.
NOTE: By following the steps below, the default Automatic Paper Type setting will be changed to Plain Paper. In order to use a different paper type in the all-in-one (e.g., photo paper), the setting will have to be temporarily changed to reflect the new paper type.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
May 30, 2008 | HP Photosmart 2710 All-In-One InkJet...
Extremely slow copying
Cartridges may give a very slow printing if internally damaged, or :
When using colored paper in the all-in-one, printing or copying is slow.This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode.
Hope this helps.
Jan 05, 2008 | HP Photosmart 2610 All-In-One InkJet...
Paper Coming from wrong tray for incoming faxes
press setup on printer select preferences and select default tray as 2 and try making copy and also check while receiving fax and also follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01096354&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Oct 01, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
HP Deskjet F4180 All-in-One InkJet Printer Logo
219 people viewed this question
Seeker5211
Seeker5211
