Question about Tomtom GO 910
Power to same, but not turning on, can't locate so-called
I have the Tomtom go 910, gets power , can see green light on, but will not turn on.. WHERE IS THAT "so-called" restart button underneath/bottom everyone refers to.. not on my 910???? I did reset but not turning on,its connected to the computer but still is off,.
    Problem Solver:
  • 12 Answers
Try lower right hand corner of screen
should reboot will ask you if you want reboot
Posted on May 30, 2009
3 Suggested Answers
SOURCE: power to same, but not turning on, can't locate so-called "reset" button on bottom????
Looking at the docking area note the gold connection terminals and which end the round coaxial connector is at. You should also be able to see the green circuit board that the terminals are mounted to. Then next to that you'll see a section of the plastic casing that has a little rubber piece in it. At the end of that part of the case opposite the coaxial connector mentioned earlier you should see a small notch in the plastic. That is the reset button. With the unit on use a regular size paper clip and gently press it in and you unit should reboot.
Posted on May 27, 2009
SOURCE: Tomtom 910 power problem
I had the same problem. I found a website that showed where the reset is. I used a paper clip and pressed the reset for 15 seconds, then pressed the power button for about 5 seconds and I was back in business. Sorrythat I can't remember the site, but it wasn't hard to find.
Posted on Oct 22, 2009
TomTom GO 910 won't turn on.
Two possibilities:
- if someone has used the wrong charger, and connected it to a 12V supply, the mainboard may be damaged. In that case, you need a replacement.
- the battery may be discharged. Even if the green light is on, it doesn't necessarily charge up. Try pushing it hard onto the mount for a few minutes, then see if it will turn on.
Feb 08, 2010 | Tomtom GO 910
TOM TOM 910
Reset button Location
Jun 11, 2007 | Tomtom GO 910 GPS Receiver
It sits in the dock with green light on but wont turn on. TomTom 910.
I'm presuming that it use to turn on,yes? try doing a soft reset by removing it from the dock and turning it over and removing the sd card (if you have one installed), and then, using a straightened paper clip or straight pin, locate the reset hole (about 1" to the left of the sd card slot) and push it for about 15 seconds. Hopefully after that you will be able to turn the unit on. If that doesn't work, you'll have to call tech support.
Jan 28, 2010 | Tomtom GO 910 GPS Receiver
It is very small - a pinhole. Use a paperclip to press the button which is sunk inside the small hole.
Jun 27, 2009 | Tomtom GO 910
look at the base of your unit with the screen facing away from you, just in front off the rubber bung is flat piece of plastic with a tiny curved out cection on the left hand side, below there is a tiny hole just big enough to poke a pin in their.
May 30, 2009 | Tomtom GO 910
Power to same, but not turning on, can't locate so-called "reset" button on bottom????
May 26, 2009 | Tomtom GO 910
Common problem with TomTom GO 910
Others have found this site helpful with the 910
Dec 12, 2008 | Tomtom GO 910
Tom tom 910 map no found bloplem
i knew tomtom 910 the best gps . so that why i buy it , but some time has bloplem i need help . if any want gps i recomender that buy the tom tom 910 is work for that money cause i got 1 year and now i bether and knew many new location .
Jun 19, 2007 | Tomtom GO 910 GPS Receiver
Tom tom 910
Try pressing the reset button, check your documentation for the location...but it's at the connection interface.
May 21, 2007 | Tomtom Go 910 (Europe, USA and Canada...
Tomtom GO 910 Logo
161 people viewed this question
Top Tomtom Computers & Internet Experts
Tom Chichester
Moazzem Hossain
Moazzem Hossain
jamie alexander
jamie alexander
Level 1 Expert
Are you a Tomtom Computer and Internet Expert? Answer questions, earn points and help others
