Spin cycle not engaging the tub to spin
The tub is not engaging in the spin cycle. Makes a loud clicking noise and just keep repeating.
  • cathy_hrbrt May 30, 2009
    Thanks for your response. The machine is an LG +3 Turbo Drum 6.5L model number: 005KW00877.
    Cheers
    President:
  • 1,136 Answers
HI, Could you get me a model # so I can see exactly what machine you have? If it is a Whirlpool brand, it could be the coupler.
Please let me know so I can assist you further.
Vic
Posted on May 30, 2009
  • Victor
    Victor May 30, 2009
    Sorry but this model # is not showing up for me. Did you get it off the label arounf the lid opening? Is it serial or model #?
    I need model
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
When it goes into the spin cycle it makes a loud knocking noise like a gear or belt is bad. what can i do, it is only 1 1/2 years old.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.If the bearing is getting out of its way then its faulty weak motor causing this.Check out both the bearing and the motor. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Washing Machines
Maytag Neptuen Washer makes loud noise when spinning. Sounds like an airplane taking off.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.Get the spin bearing and motor checked.Replace the faulty. You can get required parts from www.repairclinic.com
Aug 30, 2010 | Maytag Neptune Washer
When in the spin cycle it now makes a horrendous noise
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | GE WPXH214A Front Load Washer
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
Loud noise in spin cycle
it is your bearings and your transmission the noise is coming from your bearings but because you have to push the basket to get it started your transmission is bad also
Dec 30, 2008 | Maytag Performa PAV2200
LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Dec 15, 2008 | Maytag Performa PAV2200
Washing Machines Logo
171 people viewed this question
Top Washing Machines Experts
