Question about Pasquini Livia 90 Espresso Machine
Need a manual for Pasquini Livia 90
I was given a broken Pasquini Livia 90 and have paid to have it repaired. Unfortunately it did not come with an owner's manual. Is there somewhere I can download this?
  • 1,089 Answers
Hi I have one that I wrote if you want it. Send me your e-mail and I'll sent to you.
Posted on Jun 10, 2009
  • 1 more comment
  • Sturmkater Nov 27, 2012
    for me two pleas: werbeschluessel tailed a gmail.com
  • David Triebwasser
    David Triebwasser Jul 20, 2014
    I need the manual too, how do I contact you?
  • Ahmed El-Barbary
    Ahmed El-Barbary May 04, 2016
    barbary.gfx@gmail.com Please
How do i replace a touch pad
See user's manual, if any hint. Actually, didn't know that asquini Livia 90 Espresso Machine has a touchpad. Looks a really interesing device!
https://www.seattlecoffeegear.com/assets/user-manuals/pasquini/pasquini-moka-grinder-user-manual.pdf
May 13, 2015 | Pasquini Livia 90 Espresso Machine
Pasquini livia 90 will power up for only few seconds and then shut down you know what iy maybe?
Try this open the steam valve when turning the machine on, if that works then the vent valve needs to be replaced, or the p.stat is damaged.
Feb 18, 2011 | Pasquini Livia 90 Espresso Machine
I need the parts diagram for the pasquini livia 90
I found something on amazon, click here and take a look: Amazon com pasquini livia 90 parts. I hope this was helpful. Cheers
Nov 18, 2010 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90: heats up for about 5 minutes, then shuts off
Sounds like the pressure switch is not working properly and the safety is turning the machine off. Try checking the tube from the boiler to the pressure switch that might be blocked, if not then the pressure switch needs to be replaced.
Jul 21, 2010 | Pasquini Livia 90 Espresso Machine
Descaling the livia 90
The proper and only way to descale the boiler should only be done by a trained technician. As far removing the water tank goes, you simply lift it up from the left and right hand sides - this may be difficult if you have never removed it since calcium may have built up on the seal at the bottom of the reservoir - simply wiggle it side to side to remove. To clean the reservoir, you can use a green scour pad with water. If it is heavy build up you can use a product called CLR, and let sit overnight. You can save the CLR and reuse. Rinse well to remove all clr.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Apr 06, 2010 | Abernook Pasquini Livia 90 Automatic
I have a six plus year old Livia 90 Semi Automatic. It builds up pressure and then releases through the release valve, sometimes every 10 minutes, sometimes not for a couple of hours. Always quite a...
This is a simple fix. This has been fixed on newer units with a rewire kit. This rewire kit is for Pasquini Livia 90’s with serial numbers PRIOR to #49000. We have them listed on our website Part# 90000 for $30.00.
You can contact me for this part - If you are local we could install it for you. If you do not fix this problem soon, you will need a new pressure release valve. It would also be advised you get a microswitch #7633905 for $13 at same time as the rewire kit. If you still require a manual we could provide you with a digital version.
Jan 16, 2010 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90 cutting out
Sounds like your transformer inside the CPU is overheating and putting your machine into safety mode/shutting down. Or, the reservoir is not making its proper connection - please be sure it is seated properly and making its connection. Contact me, I can walk you thru removing the CPU if that is the problem. I can repair and return the CPU to you within a couple days.
Jan 02, 2010 | Pasquini Livia 90 Espresso Machine
Our Livia 90 would need a service + the pressure steam valve is leaking. Thanks in advance ! Thilo
If you are local to us perhaps in Orange County, CA we can provide service. If not you may contact Pasquini to get a local certified repair location near you.
As far as the pressure steam valve goes, you most likely simply need a new o-ring kit... we offer kits for new and older units. Older machines would use Part# KSWV-2 for $5.40, newer units would use Part# KSWV-2 for $4.30. I could explain how you could do this service yourself.
Oct 03, 2009 | Pasquini Livia 90 Espresso Machine
Where can I get an owners manual for a Pasquinin, Livia 90?
I found a writeup about this machine below. It has a great deal of information that may help you out:
http://ix.cs.uoregon.edu/~michal/espresso/livia-90.html
Additionally, you can contact the maker directly, and they should be able to supply you with a printed owner's manual. Their web page is below:
http://www.pasquini.com/
Sep 28, 2009 | Pasquini Livia 90 Espresso Machine
Pasquini. Livia 90 intermittently building up too much pressure
The part that will solve your problem is an upgraded heating rewire kit which will control pressure electronically, not manually. The rewire kit is Part #90000, $28
You may also need a new micro switch which is connected to your PStat with the rewire kit. The micro switch part #7633905, $13
These parts are in stock. I can send you these parts and instructions to install these parts in your machine.
May 21, 2009 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90 Espresso Machine Logo
1,053 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
