Question about Ryobi Garden
Runs only briefly after priming
My Ryobi 31 cc 700r string trimmer starts briefly after priming, then shuts down. It will not run without constant priming with the bulb. Does anyone have a solution? Thanks.
  • bcooper623 Jun 02, 2009
    Jim Thanks. I'll try the soak first, then the kit if necessary. The unit is about 5 years old and used to run well, until I left it out in the rain one day!
    Roger
  • 1,041 Answers
Yes, Depending on how old your trimmer is, one of two things is wrong. Either the carburetor just needs a very good cleaning, or you need to purchase a carb. kit and replace the small screen, gaskets, and needle valve. It would probably be good idea to do both if your trimmer is more than three years old and if you have never replaced parts on carb
Jim
Posted on May 30, 2009
  • Jim Parker
    Jim Parker Jun 02, 2009
    Thanks for the rating "bcooper623". If you should have any Questions about drywall finishing/patching, or know someone who does, put your questions to (Tools-Building & Power-Hand Tools) at FixYa.com
    thanks Again,
    Jim
  • Jim Parker
    Jim Parker Jun 03, 2009
    You should still be able to clean it up. I've got confidence in you.
    Jim
Need part for ryobi trimmer no.700r
There are parts and part number listed on page 20 of the manual. Here is the link for the Ryobi 700R trimmer manual.
Jan 07, 2013 | Ryobi Garden
I need to know the fuel-oil ratio/mix for my Ryobi 700r String grass trimmer.
Start with 40:1. If it smokes, go to 50:1. Good luck...Lee
Aug 29, 2010 | Ryobi Garden
Ryobi 700r trimmer does not start. Changed spark
hve you checked the HT lead and the on/off switch i had the same model as this and i changed everthing but in the end t chucked the thing away and got a sthil modle
Jun 21, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Husgvarna string trimmer stahls.
Try getting some carb and choke cleaner and spraying down the carb. You might have some varnish in the carb and it won't let the fuel flow properly. My ryobi 4 cycle trimmer does that every year. I clean the carb and it usually runs decently.
Good luck
roundo4
Aug 09, 2009 | Garden
31 cc Straight shaft/ head won't turn when connected and running
pull the shat off the engine and check the inner shaft it sounds like its stripped or the theengine side is cracked hope this helps
Oct 22, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
chad
Oct 03, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
363 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
