Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer not heating, help
I have the fridgidaire gallery dryer- model number gleq2152eso. it is giving me a code that says "AD". it is also not giving any heat at all. some say it is a fuse problem but i am unable to find any fuses. please help, the cloths are beginning to stink. thank in advance
  • 6,784 Answers
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on May 30, 2009
What might be wrong with my gallery dryer #gleq2152eso it does not heat?
Hi friend, I appreciate your post!
Based off the information you have provided your Frigidaire dryer, GLEQ2152ES0, is no longer heating. I understand that you heard a noise like pennies hitting the drum and then it stopped heating. Some possible reasons to why your dryer is not heating could be that your vent is restricted, an issue with your thermostat, or heating element. I would recommend having a technician come out to diagnose and repair your appliance because with the noise you heard he may need to disassemble the dryer. I hope this is helpful. -Matt
Aug 12, 2014 | Frigidaire Dryers
Fridgidaire electric Dryer model gleq2152eso display LOC and wont start.
Press option and select (button with lock) at the same time and hold for 10-15 seconds.
Jan 18, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Fridgidaire GLEQ2152ESO dryer will not start or run- worked perfectly earlier in the day
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 18, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer will not turn
hello check to see if the long pin inside the door has not snaped off if thats ok .then check capacitor next to the motor inside the dryer may have blown
regards
shaun
Mar 01, 2010 | Frigidaire Electric Dryer
I have a gas Frigidaire Gallery dryer. There is an error code "LOC". I can't get it to work now.
This indicates there is an error with the door lock mechanism. It will most likely need to be replaced. This will prevent the dryer from working and is a safety feature to prevent injury while the dryer is in operation. It is fairly quick and cheap to repair.
Oct 07, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire GLEQ2152ESO Dryer flashing AD
AD means "auto dry", which means the dryer is supposed to be detecting the moisture levels in your clothing and adjusting the drying time accordingly.
If your dryer is flashing "AD" and turning off shortly after the start, there is likely a problem with the mechanism designed to detecting the moisture levels. If it turns off after trying to use all various settings (including the no-heat feature), it is likely a wiring issue.
Mar 27, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Heating elements on gas dryer
Okay...the write-up you read was advice for ELECTRIC dryers. The model number you provided is for a GAS dryer. You have a burner assembly in your dryer instead of a heating element. The likely culprit on a gas dryer that no longer heats, is the igniter. The following link will shed some light on how the igniters work:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
I know the link is for advice on how to replace an igniter in a gas range, but the theory of operation is the same. Read the top portion of the link I provided.
The igniter will become weak with age and will either stop glowing, or will glow, but not draw the necessary current to open the gas safety valve. This is a designed safety feature that prevents free flowing gas from entering the dryer cabinet without ignition. I would recommend you check first to see if the igniter is glowing. You can see an illustration of what I'm talking about by going to searspartsdirect.com and entering your model number. If you look under the "Burner,Valve" heading on the next page, the igniter is listed as item 74. Let me know what you find.
Dec 17, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
671 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
