Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
Francis Francis X1 blowing thru ESE pod
I have a Francis Francis X1 and I used pods...it seems to blow a hole in the pod and then spew out the espresso full of grounds from the pod. Anyone know what's wrong with it? I have only had it for about 1 1/2 yrs.
    President:
  • 1,618 Answers
Check the group head shower, make sure it does not have any defects(cracks, scratches or unusually large holes).
Posted on May 31, 2009
After the pod is put into the machine doesn't pump the water through
had that probleme ( if you check the pin that pierce that k cup or pod ( it has small hole in it take a tooth pick and put it true that hole to get the dried up coffee out ( if that seem to not work ( u can blow in that needle also) and if that dont work take the top off ( screws ) and find the feeding line could full of dried up coffee ... ;) that is your problem
May 14, 2017 | Coffee Makers & Espresso Machines
I cant get my Gaggia Classic to work with pods
You need to use the single-serving size one-hole basket, not the double, with the diffuser valve seated beneath the basket. Then the Illy ese pod should be inserted with the decal facing up. Finally, and most importantly, when you lock the filter assembly into the machine, you need to close it firmly. Brown water can mean that the basket assembly is not sealed in tight enough.
Sep 07, 2014 | Gaggia Classic Espresso Machine
I have a Gaggia classic and want to use pods. I've got Illy ese pods and the right (one hole pressurised basket) but still get just brown water. Can anyone help please?
I HAVE BEEN USING THE GAGGIA CLASSIC FOR 34 YEARS AND I ALWAYS BELIEVED THIS MACHINE IS BEING DESIGNED FOR SPECIFIC COFFEE QUALITY. THE ILLY ESE PODS ARE NOT FOR THIS MACHINE, TRY LAVAZZA PODS INSTEAD THAT IS SHAPED PERFECTLY WITH GAGGIA FILTER HOLDER FOR PODS.
Ground Coffee Kit/Holder
There were two versions of the Francis Francis X1; one without the logo (older) and one with. I guess your only chance is ebay; but why would someone sell the holder without the machine?
May 27, 2014 | FrancisFrancis! X1 Espresso Machine
Can I adapt a Francis francis x1 to take ese pods?
My X1 came with an ESE pod holder and a ground coffee holder so they are definitely available.
Dec 02, 2012 | FrancisFrancis! Coffee Makers & Espresso...
Í have a francis francis X1 for 3 years now.
Hi
There are 4 nuts that hold the chrome head on. They are either 7mm or 8mm nuts. Loosen then and the head should twist out.
Nov 23, 2009 | FrancisFrancis! X1 - Stainless Steel...
I recentlty bought a Francis X1 (2000 model). I
There are two different handles made for this unit (I own an X1 and have both). Both of these handles have baskets.
First - The pod handle has a basket area that is very shallow, about 1/3 of an inch deep and the basket has very small holes.
Second - The handle for loose grounds came with two baskets, one for a single dose, and one for a double dose. Both removable baskets have the very small holes for the espresso to drip through.
You must have a basket in the handle in order to use the machine. If you try to make espresso without a basket, you'll just make a mess. Besides, the machine will never be able build enough pressure to extract espresso from the grounds.
Search the net (ebay?) for francis francis x1 handle.
Good luck
Feb 24, 2009 | FrancisFrancis! X1 - Stainless Steel...
I have a Francis X1 Trio. Has anyone ever tried to use ground coffee and can it work. I hate the pods and would love to try to use regular ground with a tamper, but I'm afraid of ruining the machine.
You need a ground coffee adapter, these are available from various sites online. Do a web search for X1 ground coffee handle and you'll find one. Make sure it's the right one for your machine (check to see if you have the aluminium or brass boiler version)
Just found this site - It's in the UK and I'm not sure if you are but they will probably export to you.
http://tinyurl.com/lhxvg6
Regards
Richard
Feb 18, 2009 | FrancisFrancis! X1 - Stainless Steel...
Need filter part
ok try coffetech .co.uk call them ther will send u parts list
May 27, 2008 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis X1
Some leaking from the group head of the machine is totally normal while the machine is heating. The reason for this is that the valve that sits above the shower screen is simply a spring and rubber ball. The spring expands, creating a seal with the rubber ball and the boiler, once the boiler reaches a specific temperature. Until the boiler temp is reached, leaking from the group head will occur.
Feb 26, 2008 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
327 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Joe Lalumia aka...
Joe Lalumia aka...
billconfused
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
