Automotive AC Prob
The AC only blows external air meaning if it is hot it blows hot air and if it is cold outside it blows cold air but will not cool car in hot weather or heat in cold weather.
  • 4,654 Answers
Automotive AC is a complex thing to resolve. I have rebuilt many and have seen what it takes to make them work correctly. Now send me make, model, year and engine type and from there I can help you solve your problem. Thanks, Sea Breeze
Posted on May 30, 2009
Air conditioner blows cold except at a low idle
Sounds like your AC system is low on coolant. Higher rpm will pump enough to cool but at low rpm low ststem will not cool. You need to go to someone who services AC systems or if you are a DIY person buy a refill kit at an auto parts store or a store with an automotive section.
Note you will be to be familar with servicing AC and be able to locate the site class and know the type of coolant you need if you have an older vehicle.
May 25, 2012 | Jeep 2004 Grand Cherokee Laredo
2000 NISSAN 4X4 P/U A/C SYSTEM WILL BLOW COLD WHEN OUTSIDE AIR TEMP IS COOL, WHEN HOT OUTSIDE AIR BLOWS HOT.
your auxillary fan is not working. this fan is responsible for cooling the freon that is being circulated in your cooling system... check if there are any loose wires in front of the engine bay.
the auxillary fan is located right beside your radiator fan.
May 17, 2012 | 2000 Nissan Frontier
I want all cold air it blows hot out the back why
the back should blow out hot and at the front it blows out hot
the hot is the air in your room
Jul 22, 2011 | Heating & Cooling
A/c works fine in the morning, blows out vents at 55* - 59*. later in the day, and as it gets hotter outside, a/c blows hot air. What's up?
could be slightly low on charge-or cooling fan is not working-as the temp outside goes up the ac needs to be more efficent to blow cold air--and really 55 is not that cold--depending on outside conditions should be able to blow at low to mid 40 s
Aug 16, 2010 | 2003 Ford F250 Super Duty Crew Cab
AC not blowing cold air
have ac checked and refilled
Jul 04, 2010 | 1997 Mercury Mountaineer
Ac not blowing cold after outside temp reaches 98 degrees
Sounds like you have dirty condenser coils. Remove the upper shroud and check the condenser for clean. Take a water hose and gently spray out the coils paying special attention not to bend the coils over with too much pressure. This will allow more air movement through the coils and give you better cooling efficiency.
Hope this helps,
Jeff
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Ac BLOWING HOT AIR INSTEAD OF COLD. All of a sudden my AC started blowing hot air instead of cold. It is set on cool.
Check to see if your outside unit is running. If not, check the breaker. If it is running you may have an issue with the reversing valve. It looks like three lines coming out of the top and one on the bottom. Trace the wires back to see that they are tight and secure. Of course, TURN OFF THE POWER first. good luck.
Apr 18, 2009 | Hunter 30124 Air Conditioner
2001 bmw 325i AC blows warm
PROB NEEDS 2 JUST BE RECHARGED. BUT STAY AWAY FROM THE DEALER. IT IS ALWAYS 3 TIMES MORE THAN A PRIVATE SHOP
Mar 30, 2009 | 2001 BMW 325
Not cold air cool air?
Check your air filter. if its ok call the guy who installed it and have him fix the leak. It prob is a bad weld joint. Check the joints on the copper tubing inside at the coil and outside at the a/c and feel around and see if there is oil leaking from the joint. If not you may have a leak in a coil or on the txv inside on the coil.
Aug 31, 2008 | Weather King 10AJA3601AH Air Conditioner
Cooling problem
Since it is not so hot outside you may have to adjust the Thermostat to a lower setting to get the AC unit to kick on the compressor and blow out cold air. Give it a try, and if not the T-stat then we can go from there.
Jul 14, 2008 | Office Equipment & Supplies
Heating & Cooling Logo
217 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
