Question about Schwinn Mesa Gs Mountain Bike
The left brake is disconnected, how do I reconnect it?
When I squeeze the left hand brake it does nothing, the brake at the tire doesn't move
    President:
  • 1,138 Answers
You'll have to remove the mounting bolt from that arm with the proper size allen key. Clean the post and lube it. While you have the arm off have a look at the spring . It may be broken or just disconnected from where it is supposed to be attached. Also check that the brake cable is moving freely in the guide(noodle) and is attached properly to the opposing brake arm.When you have the pivot lubed slide the brake arm back on and make sure it pivots properly. Readjust the brakes and you should be in business. The front brakes and the back brakes work the same so look at the working set and compare to the non working set if you need a guideline to go by. If you have hydraulic brakes you will have to take the bike in to be serviced as it requires specialized tools. Hope this helps.
Posted on May 30, 2009
Driver rear tire is locked in reverse but going forward is fine. Hand brake is off. I really need help with this guys. Anything is better than nothing. Thanks
Check the MECHANICAL (parking) brake shoes BEHIND / or on the inside of the rotor of the rear wheel in question.
If the piston isn't coming out on the caliper to allow the pads to squeeze the rotor - that make explain why the pads / rotor look good - they're probably not being used.
Oct 29, 2015 | Cars & Trucks
How do I adjust the brakes on my bicycle?
Re position the braking assembly so the stationary pad is just about to touch the rim and tighten. Then with the adjustment adjust the pad that moves so that it applies appropriate braking force when you squeeze the hand brake.
Oct 06, 2015 | Specialized Cycling
Quick release bike tire installation
the pads don't need to be removed. Most brakes have a "quick release" on them. On linear pull brakes, use one hand to squeeze the two lever against the rim and with your other hand you can pull the "L" shaped cable noodle out the bracket and this releases the brakes. (you can also let the air out of the tire and install the wheel then reinflate the tire once you have it back on the bike). On road bikes with side-pull brakes most have a small lever you can flip up that activates a cam mechanism that opens the brakes up to allow the tire to pass through. Canti-lever brakes are similar to linear-pull brakes, just squeeze the brakes together and release the straddle cable. Hope this helps.
Aug 13, 2014 | Cycling
Brakes freezing in reverse and back right tire won't move by hand when jacked up
Sounds like you have a stuck caliper, they run $35-50 for the rears on that vehicle, They are not that difficult to replace, just be sure to bleed the brakes well after replacing it and check for leaks. If it has been like this for a long while. I would inspect the brake pads, and rotor while your there and replace them if they are worn.
May 11, 2012 | 1997 Plymouth Voyager
How do I adjust my hand brakes?
There is an adjusting screw on the handle and one at the bottom of the brake cable. Squeeze the brakes by hand tight on the tire and adjust the scews.
Feb 12, 2012 | Gary Fisher Presidio
Clutch pedal goes strait to the floor??clutch won't bleed up??
It has air bubbles on the piping, fill the deposit with brake solution, and push and pull the clutch pedal with your hand it doesn't matter if it goes straight to the floor if that happens pull it with your hand, repeat that as if you are bleeding it up, then disconnect the piping beneath the car, the air bubbles will be forced out, then reconnect the piping and repeat the procedure, push and pull the clutch pedal like a 100 times, then disconnect the piping and reconnect. The clutch pedal should be able to go back when there is no air on the piping. If that doesn't work, replace your clutch pump
Jun 23, 2011 | Honda CR-V Cars & Trucks
Left e-brake on and drove 6 months ago wrecking the cable which leaves the e-pedal down. And now no e-brake. Today rotated the tires and put the truck back on the ground only to find that it will not...
Pull the ebrake pedal up with your foot while pulling the ebrake handle with your hand. The ebrake on the wheel that is locked just disconnect it from the wheel brake! cheap fix
Mar 24, 2011 | 1990 Dodge Ram
Front brake disc is all there but no brakes (hydraulic front disc)
1. Does your brake piston moves when your squeeze the brake, if not the use rebuilt kit to repair them.
2. Does your brake pads in good condition (new), if not get a new set.
3. Can you bleed the brake fluid out, if not clean the bleeder valve to ensure nothing is blocking it.
4. How is your brake hoses, are they in good condition, when you unbolt brake hose banjo bolt and squeeze hand brake does brake fluid flows out easily, if not then clean the banjo bolt and if neede replace brake hose. Keep your brake master reservoir full at ll time.
5. In all process try always to work clean as any dust and dirt speck can cause havoc.
6. Good luck - cheers
Nov 18, 2010 | 1974 Honda CB 200
Rear left tier
Tire* -- I don't know if I would suggest doing this yourself, but try taking the tire off, (this requires you to jack the left rear *tire* off of the ground), and checking to make sure your brake is disengaged, meaning that neither the drums (or pads if it is the sport neon) nor the parking brake is still engaged. If neither are, you have a more serious problem on your hands, but if they are engaged, remove the drums and reassemble. Make sure your springs are in the right spot.
Mar 17, 2010 | 2004 Dodge Neon
The housing of my brakes on the handle bars is loose and keeps moving. how do i tighten it so that it stops moving when i apply pressure on it and/or squeeze the brake lever??
If the screw is all the way tight and still slipping ... try to find a fatter part of the handle bar to mount the grip to. You will probably will not find any such that is convenient for you to continue to use the brake ... remove the grip, wrap some electrical tape around the handle bar, reattach the grip. Tighten it and give it a try.
I hope this works for you
a
Oct 12, 2009 | GMC Denali Road Bike
Schwinn Mesa Gs Mountain Bike Logo
238 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
