Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer
I have had my whirlpool duet for about three years and once in a while the water will only fill up on the fabric softner side and will not take out the soap out of the other side so I have been putting the soap on that side and then wait for the rinse cycle to start and then fill it with fabric softner what can I do to correct the problem
  • 64 Answers
There may be an ajustment above the soap drawer unit. Take the lid off to see. If there is an adjustment its a 'trial & error job' to set it right. TURN THE POWER OFF FIRST
Posted on Oct 26, 2007
  • keith wagstaff
    keith wagstaff Nov 01, 2011
    I suspect the cold water valve which allows water into the 'soap section' of your detergant compartment is faulty & will not allow the water to enter via that route.
    Since the water does enter via the 'rinse aid compartment', I strongly suspect this to be the answer. Most probably you need to replace the electric solenoid rather than the complete valve assembly.Let me know how you get on. Keith
My top loader whirlpool (3yrs old) appears to be causing stains: after careful monitoring it appears the fabric softener container conitunes to leak/drip/run down the central column - so staining sheets,...
You can try a few differnt things, staining is usually caused by not hot enough water to disolve or hard water issues. A Washer cleaning use one gallon white vingar fill up washer with hot HOT water let sit over night than run washer next day on HOT hot. Second try washing in warm to hot water dluting softner more breaks down better. Also dluting the softner more in the cup will help washing in cold causes alot of these issues, Make sure water heater turned up hot enough, make sure washer has hot water fill?
Aug 23, 2011 | Whirlpool Washing Machines
The fabric softner compartment of my whirlpool duet washer is completely full of water
Mine is doing the same. For over 2 months now I've been adding fabric softner to the detergent compartment but I broke down and called a repairman to come tomorrow... at a ridiculous repair rate. My washer is less than 3 years old and this will be the 3rd major problem that needed to be fixed. I've seen a lot of people post the same problem - some say all 3 compartments won't drain.
Feb 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water left in fabric softner area when load is done
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
Feb 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer, dispenser problem with fabric softner
maybe it's clogged take the drawer out and see if the water flows out of that side ok. put into rinsea nd spin and it should put water into that side.
might take a minute
What happens let me know
make sure you have a towel ready
Feb 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Fabric Softner
that is normal you can either add water to make it drain or pull out the drawer and dump it.
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet frontloader washer's dispenser stays filled
I had a similar problem, but mine was with the detergent side. I removed the top of the washer and had to clean the dial that advances to let the cyle of dispensing continue. It worked, but now the machine shakes and I am told is 'unbalanced'
Jan 16, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Tray that holds fabric softner does not drain
I have had three sepaerate service calls and one independant analysis about this problem. For the whirlpool duet washer - this is a design flaw - nothing else - please notice that when you take the detergent tray completely out (and turn it upside down) a piece of plastic falls out but even if you put it back correctly the water only flows out into the washer - either washing everything away or leaving it behind - I have been told there is no fix.
Aug 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet fabric softner problem
It obviously is backed up or splashed in from the wash. And if it is just water why worry about it.
Aug 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Water in bleach/fabric softne compartment
Purchased the duet washer and dryer sept 2004..have had the same problem with water staying in the compartments. while under warranty had to place 2 service calls..the last tech order a new bleach compartment...that helped for a few months, but back to the same problem with having to pull entire container out and empty..i do remember the tech saying that whirlpool duet was first introduced in germany...then the united states...they have had the same problem...and that whirlpool is awhere of it, but nothing can be done about...except keep emptying compartment when it fills with water...our neighbor bought a duet washer last problems like we are having..whirlpool must of solved that issue with the newer versions.... paying $1000.00 for a washer and having to empty the compartment everytime doesn't make sense to me.
Dec 12, 2006 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
128 people viewed this question
Dan Webster
Dan Webster
Sal De
