Question about Janome Memory Craft 3000
Bobbin thread bunching
The Bobbin thread is bunching up under the garment, garment not feeding.
    Problem Solver:
  • 12 Answers
Tension is tooooo loose.
slowly tighten
also the pressure gauge at the top should be for accurate fabric thickness
Posted on May 30, 2009
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
The cotton not bunching up in the bobbin case
Install a brand new needle.
Remove all the thread.
Clean the lint and debris from the bobbin area, feed dogs, and under the needleplate. Oil as (if) recommended in the manual--use only fresh, good quality sewing machine oil--and only 1-2 drops each place.
Always RAISE the presser foot when threading! Rethread from the beginning confirming the thread path is correct.
Set the upper tension to the midway point. The tension will probably need some tweaking to get it where it should be for your project. (Tweaking tension is a common & frequent adjustment to make, especially when changing projects using different fabric weights, thread, etc.)
Retest your machine.
If it is still globbing thread under the needleplate, you may need to take it for service.
Jun 04, 2016 | Sewing Machines
When i sew the underneath thread bunching up under garment I have tried all the trouble shooting on you tube, tried all different tensions still same results. Have a Taylor professional 834fb
the problem is the needle thread tension is not tight enough
tighten it up until there is a definite resistance when pulling the thread by hand
Apr 09, 2016 | Taylor Sewing Machines
Doesn't sew correctly under fabrics ,top is ok
To give you useful information it would help to describe your machine and your problem in detail.
Mar 07, 2016 | Sewing Machines
Thread tangling inside bobbin case catching on another part
1. thread machine correctly.
2. make sure bobbin case in spinning in the case in the correct rotation. If the bobbin is spinning off of the bobbin incorrectly, "bird nesting" is the result.
Jul 20, 2014 | Brother NX-400
Brother sewing machine model vx 1140
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Also could be a timing problem, and the machine would need to be checked.
Sep 08, 2013 | Sewing Machines
The thread is bunching under the fabric even though the stitch looks perfectly find from the top
Change needle-flat side to the back of the machine
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& make sure bobbin is wound correctly & that it is inserted correctly in the bobbin case or shuttle
Check tension 3 or 4 is usually good
with some machines the thread comes off the thread take up lever
Nov 24, 2010 | Singer Sewing Machines
When sowing the thread bunches up in a ball. The inner rotary make noise, how to correct problem?
first change the needle
clean under the needle plate where the feed dogs are for lint
also clean the bobbin area for lint or loose threads
rethread the machine-top thread & bobbin
some time the top thread can come off some thread take up levers--that should be watched when sewing
check to make sure the bobbin is always wound correctly--and incorrect wound bobbin can cause sewing problems
Nov 17, 2010 | White Sewing W3300 Computerized Sewing...
Top thread - not bobbin thread - bunches up under fabric where feed dogs are when I'm embroidering.
this is a top thread tension problem . make shure thread is between tension plates and spring is contacting the plate if the tension number is high
Apr 12, 2010 | Baby Lock Ellure
The bobin thread bunches up on the bottom side of garment.
Try these solutions.
* Re-thread your machine as it may be threaded incorrectly.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Dec 20, 2009 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
335 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
