Question about HP Photosmart C6180 All-In-One InkJet Printer
Paper Jam My paper is jammed how do I unjam it
  • Anonymous Nov 22, 2007
    My printer is getting a paper jam everytime I try to print from my computer, but it will print a copy without issues.  What gives?  How can I fix this problem?
  • 1015bert Dec 20, 2008
    I can print from notepad but I can't print from Word or IE...  It jams from Word and IE but not from notepad... Any ideas
Locate at the back portion of your printer there is small rectangular like a door pull up and then get those paper that causes paper jam slowly see to it that there is no paper left....and start printing again if it does not worked then try to clean your paper rollers...
Posted on Nov 05, 2007
THANK U SO MUCH PROBELM SOLVED
Posted on Jan 29, 2008
5 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: paper jam hp 5510
Look in the rear of the machine for an access door.
Posted on Jan 04, 2009
SOURCE: DUPLEX PAPER JAM
I posted previously. After buying new paper, the duplex printing is working. It is probably heavier than my previous paper, but not particularly thick (don't know the exact grade.) So if you have this problem, try buying some new paper a little thicker than you are using now.
Posted on Jan 25, 2009
  • 685 Answers
SOURCE: hp 6310 officjet all in one paper jam error
This video won't help if it's really broken, but shows you what to do for a recurring jam on the 6310.
Posted on Dec 23, 2009
pineworks
  • 4041 Answers
SOURCE: paper jam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
Testimonial: "good advice, worked. No better place than FixYa.com to get expert advice!"
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Jun 30, 2016 | Shredder Office Equipment & Supplies
Misfeed detected. Remove paper indicated by 0
misfeed is different then a jam. jam is the paper hit something miss feed the paper rollers can not pick up the paper. clean the rollers or replace them and or there associated clutches
Feb 21, 2014 | Konica Minolta Bizhub C451...
How to unjam paper jam?
There are a number of things that can cause a carriage jam.
To prevent it from recurring, one should keep in mind a number of things.
Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside.
Also the paper being used should be as per the manufacturer's recommendations.
Turn off the printer when removing bits of paper.
If there is a broken gear, do not repair it yourself.
Call an expert technician to mend it. get more help for HP Carriage Jam .
Aug 04, 2010 | Cisco Photosmart C4780 Wireless AllInOne...
Paper jam kodak esp 5 message even though i don't see one how to unjam paper
usually paper jam is at the back of the printer for more information see your printer manuals
Jun 23, 2010 | Kodak ESP 5 Printer
I'm trying to replace black color cartridge, but get an error message: carrier jam How do I unjam it? Already did the unplug- check for paper jam and replug...no luck!
Remove all paper...(inspect closely for paper jammed way inside!)
also remove both ink cartriges, reinsert them one at a time carefully and properly....also double check the number code on the ink
the jam error could be either paper or cartriges confusing the printer. let me know if it works....k
Apr 19, 2009 | Dell 924 All-in-One InkJet Printer
Hp 6310 officjet all in one paper jam error
Apr 01, 2009 | HP Officejet 6310 All-In-One InkJet...
Paper jam hp 5510
Jan 04, 2009 | HP Officejet 5510 All-In-One Thermal...
HP Photosmart C6180 All-In-One InkJet Printer Logo
513 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
