Question about Whirlpool Washing Machines
Found oil and grease under washing machine. Makes loud noise when on spin cycle.
When I moved my washing machine out to clean under it, I found what appeared to be oil and black grease. The oil was dry and the size was about 8"x12" (oval). The grease was about 3"x4". It's also been making a lot of noise when it's going through a spin cycle. With the oil and grease leak, it doesn't sound to promising. I'm hoping I can repair it myself. I pretty handy, besides, I can't afford a new one. Rosanne
You can always find the cheapest prices on Amazon or Ebay.
Posted on Mar 02, 2013
    Problem Solver:
  • 6 Answers
The oil and grease is probably from the transmission and yes you might be able to replace it. Get your make andmodel number and go to www.repairclinic.com. It is a very good site for finding pictures and parts of appliances. The parts are as cheap as you will find them. If the oil/grease is from the transmission, it will eventually fail. Fix it now or fix it later. Your choice.
Posted on May 30, 2009
What causes our front loading washer to make exceeding loud noise when it enters a spin?
Sounds like a bearing seal is going. The seal has ruptured and grease of seeping out. The loud noise is the bearings rubbing against each other without adequate grease to reduce the friction. Failure will come soon if it is not fixed. The vibration is coming from the friction and possibly damaged ball bearings .
Mar 11, 2015 | Washing Machines
My Haier washing Machine vibrates and makes a very loud vibration noise.
Have you noticed any grease or oil stains on clothes coming out of the washing machine?
In my personal experience, heavy vibration and loud noise during spin cycles has been caused by the bearing being broken and further damage caused by running on a broken bearing. If that is the case it is a costly repair, I had to get a new washing machine.
Washing machines are simple to take a part to a small extent, just remember in what order you took things off if you decide to investigate further your self.
Dec 15, 2014 | Haier Washing Machines
There is grease coming from uner the washing machine and it makes a loud noise when it is spinning? Sometimes the washing machine will get hung up on the spin cycle?
Oil usually from the leaking transmission. a clutch not engaging might make a noise but u will get no real spin and clothes remain wet? if it was bad motor coupler if u have direct drive u would also have no spin or wash cycle. I suspect a bearing prob withing the tranny SORRYYYYYYYY :(
Oct 17, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Loud Noise on Spin Cycle
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 16, 2013 | Washing Machines
Whirlpool clean touch top loading washer suddenly makes very loud noise. Pump works but agitator and drum won't spin. Also seems like oil leaked out of motor. I'm thinking motor seized.
If you found oil underneath it, then you have a broken transmission case, or a bad seal. The electric motor does not contain oil. This should be something that yuo can confirm visually.
Dec 27, 2012 | Washing Machines
Washing machine makes loud noise in spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Dec 05, 2010 | Kenmore Washing Machines
I n the spine cycle the washer makes a loud noise and shakes.I found a dime under the tube between the rim and door gasket.
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 22, 2010 | LG WM2016C
When in the spin cycle it now makes a horrendous noise
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | GE WPXH214A Front Load Washer
My Washing machine makes weird noises
hi,
There might be the problem with bearing of rotor mechanism or some garbage so please clean it .
Thanks
Aug 12, 2009 | Admiral AAV7000A
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Washing Machines Logo
1,346 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
