Question about Uniden BCD396T Handheld Scanner
Radio Shack PRO197 works at friend's house but not at my house!
I'm trying to pick up Indianapolis' new APCO 25 signals and I'm surrounded by tall trees and close to TV transmitter towers. My small Radio Shack rooftop antenna and old receiver worked fine until Indy went digital and I bought the new PRO 197. I also tried a Uniden equilivant radio and got the same results - short bursts of garbled voices. The Uniden AND the Pro197 work great at several friends' houses - but NOT at my house.
    President:
  • 2,761 Answers
This seems to be a common problem with all digital systems (especially with TV signals), and the ONLY solution is a better antenna. I suggest you search eBay, Scanner Master, etc. for a low-end (price-wise) discone and mount it as high as you realistically can.
The BEST scanner in the world is only as good as the antenna that feeds it!
Posted on Jan 02, 2010
Is this APCO-25 capable,the APCO-25 is the digital
No. The PRO-97 can receive both standard and trunked analog signals, but it is not digital capable. Also, there are no add-on boards or circuit modifications that can enable digital operation.
Bill B.
Listening in since the 60's
Feb 17, 2011 | Radio Shack Pro-97 Handheld Scanner
How can i get my pro 164 to pick up digital broadcast frequencies
Sorry, but your PRO-164 is an analog-only scanner. There's nothing you can do to or with it to receive and listen to digital transmissions. If digital systems are in use in your area you'll need a digital (APCO-25) equipped scanner to listen in to them.
Bill B.
Jan 11, 2011 | Radio Shack Pro-97 Handheld Scanner
I have a uniden bearcat scanner and cant pick up my local police dept. I put the frequency in and still dont hear anything. I have a bc145xl 16 channel scanning radio and want to know if its compatible...
If you programmed the correct frequency, you should be getting reception. Check www.RadioReference.com to verify the frequency. Otherwise, you may be too far from the transmitter to receive signals. Try your scanner in other locations, check your antenna, and try receiving the PD on another scanner.
The MARCS - Ohio Multi-Agency Radio Communications system - is a Motorola Type II SmartZone Omnilink Trunking system that utilizes APCO-25 digital transmissions. Your BC145XL is not compatible with trunking or digital systems. In order to follow the MARCS you will need one of the following scanners:
GRE PSR-500, PSR-600
Radio Shack PRO-106, PRO-197, PRO-96, PRO-2096
Uniden BC250D, BC785D, BC296D, BC796D, BCD396T, BCD396T, BCD996T, BCD996XT, or the brand new HomePatrol-1
Bill B.
Nov 11, 2010 | Radio Communications
Can I do a mod to receive 8oo digital? Gary deanpark2005@hotmail.com
Sorry, but the answer is no. Analog and digital signals are vastly different, and there is no APCO-25 (digital) card available for your scanner. Your only option is to replace your scanner with one that is factory equipped for digital.
Bill B.
Nov 08, 2010 | Radio Shack Pro-94 Scanner
Can the pro-94 receive digital signals
Unfortunately, no. The PRO-94 can monitor conventional or trunked analog systems, but it cannot process digital signals. To do that you'll need a scanner that specifies DIGITAL, APCO, APCO-25, or P25.
Need the manual for your PRO-94? You can download/print it here:
http://support.radioshack.com/support_electronics/doc61/61426.pdf
For a comprehensive database of active frequencies and systems in your area, visit:
BillB
Jan 19, 2010 | Radio Shack Pro-94 Scanner
Some frequncies come in with tone not voice ,lower channels come in but higher one started this morning
find out if what you are listening to has gone to digital... in particular apco 25. if so you'll need at the minimum a scanner that will work on apco 25. look at the specs on a pro-96 to see what you will need.
Jan 11, 2010 | Radio Shack Pro-2051 Base Scanner
Radio Shack PRO-96 What mode do I use for scanning==866.600 to 868.450 range and 44.82 to 155.175. The choices are== AM Mode (AM) FM/Digital (FM) CTCSS Mode (CT) DCS Mode (Dc) Motorola/APCO-25 Trunking...
You more than likely want the FM mode. If you are listening to a trunked agency then you will have to know if they are on the MOT, or EDACS system and choose the correct one.
Mar 24, 2009 | Radio Shack Pro-96 Scanner
Uniden BCD396T Handheld Scanner Logo
246 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
