Question about Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse Lcd Tv randon "No Signal" message.
I have the SK-32H540S which is a 32 inch Lcd TV. I have it plugged into my normal cable connection. Most channels work perfectly on this TV, but on some channels at random times I get a "No Signal" message and my screen goes black. After a few seconds the channel works normally again, but then a few seconds later it goes to "no signal" again. This repeats on on and on on these channels.
This didn't happen on my old normal TV I used to have nor does it happen on the 44inch Samsung lcd we have in the living room or any other TV in the house. I'm positive this issue has to do with the TV and not with my cable. I've tried calling Westinghouse but after hours of being on hold I have given up.
I hope someone can help me, thanks in advance
SOURCE: Westinghouse SK-32H540S LCD TV Turns Itself On - Appears Random
turn the timer off.
Posted on Jan 27, 2009
westytech
  • 120 Answers
SOURCE: Westinghouse SK 32H540S Turn on TV, get
Hello, it sounds like you need to replace the inverter board, I believe this model has LIPS board which is the power board and the inverter board put in to one single board. You can find price and availability for parts by emailing parts@wde.com.
Posted on Feb 03, 2010
  • 308 Answers
SOURCE: Westinghouse SK-32H540S LCD HDTV Video Comes On,
Take a strong light and put it up against the screen. Do you see a faint image? if yes, then your backlight has failed. Could be a lamp, inverter or power supply issue. Not for DIY'ers.
Posted on Apr 23, 2010
  • 3 Answers
SOURCE: Westinghouse SK 32H540S when i Turn on TV, get
The problem is cause by the transformer on LIPS inverter (Power supply + Inverter board). You could see an obvious burn on the 1 of these transformers ( There are total 3 black transformer on this board). The part number is 4302H. It is available online at http://www.lcdparts.net/TransformerDetail3D.aspx?ProductID=2775
Posted on Jun 12, 2010
sonicboomele
  • 1557 Answers
SOURCE: Westinghouse SK-32H540S 32 in. LCD TV It went off
i have been a tech for 26 yrs now i have seen so many postings on here about bulging caps and so on but there is only 1 thing to do our workshop has 18000 dollars in test equipment alone there is a great reason for this the amount of vereables that can go wrong with nano electronics there is no easy fix to this problem it needs to be seen by a certified electronics tech this is your best chance of having this tv fixed correctly im not putting down other techs on this site but some things we can fix by computer network some we cant imagine even if this tv was in my workshop right now it would take us over an hour just to find and fix the cause
i hope this helps you sir/mam
sonic boom electronics australia pty ltd.
managing director
Posted on Jan 02, 2011
Testimonial: "Thanks That was what I was thinking I would have to do anyways, but never hurts to ask."
Westinghouse 32H540S Remote Program
You have this backwards. The codes are in the remote. If you are using a Westinghouse remote, there should be no programming necessary. If you are using a universal remote, you can use the code search function to find a code that will control your TV.
Dec 03, 2013 | Westinghouse SK-32H540S 32 in. LCD TV
How do i hook up lap top to tv that is direct tv connect?
you need a pc with an hdmi out jack or use a tower pc with a card that has hdmi out
Feb 02, 2013 | Westinghouse SK-32H540S 32 in. LCD TV
It is a 42" Westinghouse SK32H520S and it worked
It is probably a poor connection through the coax. I would replace the coax and that may resolve the issue.
Mar 24, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
My westinghouse 32 inch flat panel tv turns on i get the picture then in about 20 seconds picture goes out but still have volume. i turn it off then on again and the same thing happens ....help
This tv have a dead long board call the LCD inverter board.This long LCD inverter board job are to help the LCD screen panel to have a backlight to produced a picture.Replaced this long LCD inverter board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Dec 02, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
My Westinghouse SK-32H540S TV comes on for about 5-10 seconds, then the picture goes off. The sound continues.
You need to replaced your Inverter Board, If you can do the job, get the Board Part number and order it from Westinghouse. If not call a Professional TV Technician. At least you have an idea what's the trouble with your set. Hope this Tip will help you.Thanks
Aug 12, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse sk-32h540s TV, VGA input, image can't center.
Hello, two things, one try using the TV with the native resolution of 1366 X 768, and secondly try updating your video card. If you are not having this issue with the TV on the other inputs than most likely it is a settings issue with the laptop. Please rate this comment if it was helpful.
Apr 06, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
Canceled cable and want to tune into local channels..but only get blank screen or "no signal". bought an antenna...still nothing
you need a digital converter box because there's no more antenna / analog reception signals for American TV transmission anymore.
Jul 28, 2009 | Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse SK-32H540S 32 in. LCD TV Logo
1,324 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
