Question about GE DPSB613EDWW Electric Dryer
Start/pause blinks but we cant get dryer to start. Have cut power,tried diff settings no help in manual
    Brigadier General:
  • 3,614 Answers
try to press the cancel button to cancel or stop thye operations.
if the above steps did not solve the issue, this could be a problem on the control board, do unplug the unit for an hour, this will loose the stored power on the unit and make the control board reset the ff: error.
Let me know for further clarifications
Posted on May 30, 2009
There was a power cut mid cycle after which the start/pause button just flashes but wont start.
Is it possible that the outage was caused by a power surge that might have killed your programmer?
May 30, 2015 | Washing Machines
Dryer is stuck on paused and won't spin. Turned off and re-started but the motor ran for a few seconds and then went to paused again.
Good Morning Jill,
So I see that you were drying bath mats and the dryer got stuck in a "Pause" mode and even if you cancel and restart it shows "Pause" on the display. I would suggest resetting the dryer. What you will need to do is either unplug it or you can shut the power off at the circuit breaker. When you do this you will need to leave it off for at least 2-3 minutes. Cut the power back on, start any cycle. If you are still having trouble not being able to start the dryer and "Pause" showing, I suggest you either contact the manufacturer or your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Mar 25, 2014 | Electrolux Dryers
Lg dryer dle7177 cutting off during cycle
I had a tumble dryer that stopped working and after much investigation it turned out to be an internal thermostatic switch and lots of fluff around the internal filters. ( Mine had 2 of them 1 would cut the heat and kick back in when the temperature dropped and the other one would completely cut all power rendering the drier non usable until cicuit breaker thermostat was replaced. The reason they cut out is to prevent overheating and possible fire. When the thermostat gets to certain temperature it breaks the circuit. Apparently you shouldn't stop the drier until it has completely cooled down as there will be too much heat which could cause a fire, which is why most drier cycles have 10 minutes of cool/ non heated air at the end. So in conclusion I would take all the filters out and give them a good clean and try to avoid opening the door while there is still a lot of heat in the drier. I'm not sure if this will help but its a starting point.
Feb 03, 2013 | Dryers
JUST MOVED TO A NEW LOCATION AND THE BRAVOS DRYER WONT WORK.POWER BUTTON WILL NOT POWER DOWN AND PAUSE START BUTTON WILL DO NOTHING.
Double check the power source, you may need to reset the breaker. It would be rare that the dryer would fault internally during transit because a gas ignitor you be the loss and you do not have one. Check the power supply and confirm you have at least 220 volt to wall and dryer. Get back to me if you need more help.
Thanks
Nov 20, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Turn on power hear it come on then turns it self off and power light starts blinking
Blinking light may be a error code----look closely and see if blinks in a sequence---3 blinks, pause 3 blinks or 5,5.
The blinking light means set is in protective shutdown, Do you see a sequence to the blinks?
I am here to help.
If needed, unplug set and plug it back in and try to turn on---watch for likely error code.
SD TECH
Sep 17, 2010 | Panasonic PT-56HX41 56" Rear Projection...
When i go to turn on the tv the red power light turns on and then starts flashing, with an all blank tv screen. I cant get anything but a black screen. The light will flash for a lil while, then the tv...
BLINKING RED LIGHT IS ERROR CODE.
1. Unplug set for a few minutes.
2. Plug back in and turn on.
3. When red power light starts blinking--COUNT THE BLINKS.
4. THREE BLINKS, pause, THREE BLINKS (ETC) IS SHORT PROTECTION AND A DO IT YOURSELF repair for some people. I have complete instructions for this repair.
5. 5 blinks, pause and 5 blinks etc is short on 140 volt line and while not as easy as 3 blink error code it points to places to look at.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
Post a comment here when you know what error code is and I will help.
REGARDS, SD TECH
Aug 16, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Equator EZ 2512 CEE Front Load dryer not starting
The blinks are the fault code on the unit you will have to watch them an count match them to the chart in the service manual
Here is a link to the service manual
http://www.appliancedesk.com/appliancedesk/service/CWD/EZ3612CEE_EZ2512CEE_EZ1612V/Service_Manual.pdf
Feb 20, 2008 | Equator EZ 2512 CEE Front Load Washer /...
Dryer won't start
try stop clear pad if that doesnt do it try unplugging the drier then plugging it back up is it giving you any f codes at all etc f1 f2 how old is the drier and how did you check the power at the outlet let me know
Dec 31, 2007 | Frigidaire FEQ1442ES Electric Dryer
GE DPSB613EDWW Electric Dryer Logo
67 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
