Question about Frigidaire GLER341A Electric Dryer
Replaced element and now dryer too hot - vent is clear
I just replaced the heating element and now the dryer gets so hot that it starts squeaking! Open the door and the heating element is glowing! No matter what it is set on it gets too hot. Vent is clear. Any ideas?
  • mbeim4 May 30, 2009
    Thanks for the answers. I hope this is where I answer your questions. I replaced the whole can - not a restring. The dryer is not hot all the time. Only on high, medium, or low heat. I can fluff the clothes (no heat) and it is ok. It starts to squeak because the metal is getting so hot it is expanding or warping. As soon as I flip the heating switch to the fluff setting and it cools off the squeaks go away.
  • Tracy Farrell
    Tracy Farrell May 11, 2010
    M,
    When you replaced the element, did you replace the whole "can", or did you do a re-string? Well, regardless of which one you did, it sounds like one of the t'stats in there (one on the can and one on the rear wall) is either NOT there or wired improperly.
    Also, is the dryer ALWAYS hot? Even when it's not turned on?
    SG
    President:
  • 1,136 Answers
Hi, Check the element again. It sounds like the element has relaxed and shorted out against the metal housing. The squeak might be the rear bearing cup. You can check and see if it needs grease while you have the drum out.
I hope this helps you. Please let me know.
Thanks
Vic
Posted on May 30, 2009
  • Victor
    Victor May 30, 2009
    It sounds like the thermostat has gone bad. For your safety I would replace them both. The only other option is that wires were placed wrong when it was put back together.
Heat problem
Sound like thermostat is not working. Should turn off heating elements when drying temp. is reached.
Jan 20, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
What could be causing inside of the drum of my AD55 F&P dryer to very hot?
see this causes and fix it. God bless you
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Sep 28, 2012 | Fisher and Paykel Dryers
Dryer is only 5 yrs old. Started to blow cool air. Not heating. Vent was blocked from outside. Cleared vent, flab is open, but dryer still not blowing hot air. Is there a reset on this machine? Why...
There is a device in the circuitry for the heating element which shuts off power to the heating element when the dryer gets above a certain temperature which is ealsily reached with a clooged vent hose. This device, a thermal limit switch or thermal fuse, cannot be reset, it has to be replaced.
If you want to do this yourself, let me know -- if not, you will need to arrange for someone to repair the dryer. The device costs about $20 -- a service tech will probably charge up to $150 for the repair.
Charlie
Jul 26, 2011 | Kenmore 600 7965 Dryer
Heating elements are lit up working normal, drum hot but not inside of drum. it takes forever to dry clothes. vent wide open no clogging inside. need help ?
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Jan 04, 2011 | Whirlpool LER5636P Electric Dryer
THE DRYER IS NOT GETTING HOT
Verify that all breakers (or Fuses) are fine, Electric dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Sometime, the dryer may heat, but it may not heat up as hot as it should. To repair, first check the vent hose. It must be clear for the dryer to work well. Make sure that the hose is not being crushed by the dryer. If the hose is very worn, or crushed, you'll need to replace it. The hose attaches to the back of the dryer and the outdoor vent with a spring clamp.
Another common cause of a dryer failing to heat is a faulty element (Heating Element). You'll need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 21, 2010 | Roper REX4634KQ Electric Dryer
We just bought this dryer and after drying a load I touched the top of the dryer and it was incredibly hot? is this normal?
Check your vent it may be stopped up this will cause the top to get overly hot and the bearing to squeak
May 31, 2009 | Frigidaire GLER341A Electric Dryer
Changed motor now dryer works until its too hot
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat (read about cycling thermostats in "Drying is too slow," above).
Drying is too slow It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer doesn t get hot
it is going to be either the igniter for the gas or the heating element
you probably have an electric igniter. it is not igniting the gas to make the dryer heat i would definantly start with that
Jan 07, 2009 | Kenmore Dryers
Dryer Top Hot / New Heating Element Smell
Any time you perform work inside a dryer, lint can get kicked around and settle on components. It is common to have a slight burning smell for a day or so. However, your dryer getting too hot to the touch concerns me. Improper air flow is the number one cause of dryer overheating problems. You may have cleaned the lint out of the interior of your dryer, but did you check the air blower and vent duct lines? In addition, was the heating elements actually bad? Or, did you assume it was bad, because your dryer wasn't drying properly? The following link can explain:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. I would recommend you remove the vent hose from the back of the dryer and attempt to dry another load. If the dryer dries more efficiently and the top panel does not get scorching hot to the touch, then you have a vent clog somewhere EXTERNAL to the dryer. If the dryer air flow exiting the dryer is weak and the dryer still gets too hot to the touch, you have a clog INSIDE the dryer.
Follow these steps, first and see what you find. If you verify your ventilation is clear and not kinked or clogged anywhere, then you might assume you have a component malfunction. I would hope to try to save you from purchasing parts you may not need. I hope you find this information helpful. Let me know if you require additional assistance.
PS Make sure you are using semi-rigid (metal type) vent ducting. It is crush resistant, heat resistant, does not kink easily, and resists rodents. It is what most manufacturers recommend. If you haven't replaced the dryer vent in a while, this may be a good time.
Nov 18, 2008 | Dryers
Towels won't get dry in GE dryer
there is a blower wheel that move the moist heat air out,i think you have a clogg on the dryer vent side or the wall vent side,they need to be cleared or the dryer holds the moist hot air in the dryer and takes forever to dry,let me know how you do--mike
Nov 12, 2008 | GE Dryers
Frigidaire GLER341A Electric Dryer Logo
210 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
