Question about Whirlpool LSR5132PQ Top Load Washer
My daughter put a big blanket int he washer. it started and then after a few minutes it stopped. I had to untangle the blanket after the motor stop working. now it will not even turn on. I am thinking
My daughter put a blanket in washer. It was too heavy and the machine stoped cold. it is only a couple of years old so I am assuming that this shorted the motor or may triped a breaker cuz the motor could not turn
  • outformahi May 30, 2009
    thanks that worked
    President:
  • 1,136 Answers
Hi, When the washer is in spin mode, do you hear the motor running at all. It could be the lid switch has broke. I do not believe it will be a motor.
To test the lid switch, Remove the screws located on the back of the control panel on each end.
Lift the control panel and let it rest on the hinges. The lid switch is located to the left and has a three wire harness. Unplug the washer before you unplug the harness and put an insulated wire between the two gray wires (not the green stipe wire)
If you can jump this, turn the timer back into spin cycle and see if it starts.
Please let me know if it helps or if I can assist you further.
Vic
Posted on May 30, 2009
  • Victor
    Victor May 30, 2009
    YOu are welcome. Please let me know if you need part # and I can look it up.
    Vic
    Problem Solver:
  • 8 Answers
This may be a problem with the lid switch.A heavy load may have broken the plastic switch.
My front load washer had a f09 then e01 code come up today. I think something is clogging somewhere
blankets can be very heavy and ball up on one side of the washer during spin cycle and cause the washer to shut down do to inballance... remove blankets & spread them ou if the are twisted up also mabe leave one of them out and rinse separatly..
Jul 09, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My daughter put a large wet blanket in the dryer and it has completely stopped rotating. I can here it turning on, but not sending the message to heat and rotate the drum
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 01, 2011 | Kenmore 97561 Gas Dryer
My machine is LG intello washer 7.5kg WD-1025FB the machine can start work, but after few minutes, it stopped and only can hear motor making noise. i turn of the switch start again, same as before: work...
Sounds like you may need new timer. They have contacts in side that control all fuctions of you machine if those contacts start failing or get burnt the machine will hit a certain spot in the timing and then it will stop or stall.
May 04, 2011 | LG Washing Machines
\\\my washer flashes a F 21 and doesn't open. I washed my son's comforter the other day and the machine stopped and flashed a F 21 and would not open. when I finally kept pushing the unlock button a...
Your blanket probably caused an out of balance on the tub which caused the washer to stop in the middle of the cycle. The lock switch is a time delayed switch. Requires several minutes before it is activated to release. When washing single items you need to add another clothing item of approximately the same weight to create a balance during spin.
Dec 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
In the Spin cycle, after 9 minuts, it will stop with a "UL".
"UL" means "Unbalanced Load" - make sure the washer isn't overloaded first or if you are doing rugs, blankets, or lots of jeans, split the load. You can also try running an empty or light load and see how the machine behaves.
If you still have the problem, you may have some issues with the drum bumpers, etc., but try the easy things first.
Jul 12, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Fast flashing
The outlet pump could be triggered because the "anti flood device" polystireen float and micro switch at the base of the washer has detected a water leak from a leaky hose or water spil) This device automatically puts the pump out motor on and stops any washing process.You need to dry the base of the washer and determine what caused the water spill. This should start the washing prosess.
Mar 20, 2010 | Dishwashers
Washer starts, runs a few seconds and stops,does it over and over
Sound like the internal overload on the motor may be going out .Thsi is usuaklly due to bad or worn bearings. If you know anything abotu electricity,take a voltage reading at the motor whe it is in the run cycle(when it stops) If you stil have have the 110Volts to the motor then the motor is bad and need to be replaced.If you do not then you wil have to look elsewhere for the problem.
Dec 14, 2008 | Amana NAV5800A Top Load Washer
Washer motor tries to start then stops
There are a number of possibilities but the easiest to check is if the brushes are worn down which would need to be physically checked or you could have a loose or broken wire in the motor block then you get on to the possibilities you highlighted which would require an engineer to test them.
Mar 28, 2017 | Washing Machines
Whirlpool LSR5132PQ Top Load Washer Logo
115 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
