Question about Kenmore Kitchen Ranges
Oven won't come on
Kenmore model #911.9382192 flashes -F4- when try to pre heat. What does it mean?
    President:
  • 331 Answers
Hi Fred!
F4 error on your model is a failed temperature sensor. Gotta yank it outta there and replace it. Yep.
I looked it up for you. The part number WB21X5301. You can get it from Sears (here) or your local appliance parts house. You can view a complete breakdown of all your oven here.
You'll have to pull your oven out into the kitchen and remove the back panel to do this repair. So... before doing anything, GO OUTSIDE AND TURN THE BREAKER OFF!!!! Is that clear enough? Failure to do this before you repair will result at the worst, in death or serious injury and at best a funky new hair do... something similar to Gene Wilder.
The temp sensor can be seen inside the oven cavity mounted to the rear wall. It's an 8" probe mounted with 2 screws. Remove these and let the sensor dangle. Now, around back (with the panel now removed, disconnect the sensor from the harness (you'll see it... 2 little tiny white wires). Now just remove it by pulling it out of the oven cavity.
All ya gotta do now is install the new one, connect it to the harness and rebuild everything. Total job time is about 45 minutes (at the outside).
This will get you cookin' again, so please remember to rate this solution. Show me some FixYa love! Thanks!
SG
Posted on May 30, 2009
Oven will not pre-heat properly
you might want to check where the thermometer is located on older models it can be knocked out of position perhaps to close to the roof of the oven which gives false heat reading
May 01, 2015 | Kenmore Kitchen Ranges
I have a flashing code on my kenmore electric oven, model 911.47709200. the code is F7 dc, what does it mean?
Stuck Keypad. Roper ovens with 2 Digit Displays:
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 25, 2011 | Ovens
M# 911 4288816 s# OV609596Q showing a F-4 code...what does this mean?
F4 is an error code that flashes on Kenmore electric ovens when the oven's temperature sensor has shorted. You should check the wiring harness and replace the sensor if necessary.
Hope helps.
Rea
Jun 08, 2011 | Kenmore 41389 Electric Double Oven
Kenmore front load washer (spprox 6 yrs old) will drain, but won't spin. Gives error F4
Hi.
No spin and F4 usually means that the problem is caused by a defective pressure switch.
The following is an extract from the washer service manual:
"F4" flashes and the cycle signal beeps when the recirculate pressure
switch is not working properly during the Catalyst, W ash or Soak cycle.
If "F4" is flashing, check the following:
- Plugged recirculate hose (black hose).
- Plugged or disconnected air tube (clear tube).
- Wires to the recirculate pressure switch disconnected or not
connected correctly.
- Failed recirculate pressure switch. Switch (black wire, tan wire)
contacts should be open with pressure applied and closed with
no pressure.
Try disconnecting power by tripping the circuit breaker or disconnecting power cord for five minutes. If that does not clear the error check the thin clear rubber hose connected to the pressure switch and extending into the tub. Try blowing into pressure hose and clean it. If that does not fix the problem replace the pressure switch.
To locate parts and diagrams, please enter the full model number, as witten in service tag, in this website.
Regards.
Ginko.
Jan 13, 2011 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Self Cleaning Electric Range and I am getting F3 and and E2 Codes. When trying to pre-heat the oven, an F3 code appears and then the oven shuts off. Sometimes while trying to pre-heat...
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking and replacing an oven Temperature Sensor .If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Nov 09, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
What does F4 on microwave display mean?
This Kenmore is made by LG for Whirlpool. Confused yet? :D
F4 means you have an open humidity sensor.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site here, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
But Sears parts can usually be obtained for far less here by entering either the part number.
Apr 22, 2010 | Kenmore Microwave Ovens
Kenmore ovens flashes -F4- when I try to set it to bake? What does this mean?
The problem likely originates from the oven temperature sensor. While not all but most manufacturer's use the "F4" code for a shorted or open sensor, you'll need to provide your model number to be certain. If you are able, check the value of the sensor, it should be approx. 1100ohms at room temperature, if not, replace it.
**Unplug the unit from the wall before performing any service**
hope that helps,
Good Luck :)
Oct 26, 2009 | Kenmore Ovens
What does it mean when it flashes f4
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 14, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite Microwave Model No. 721.64683300 does not seem to be heating well and will shut off and flash an F9 code. What does the F9 code mean
Oct 07, 2009 | Kenmore Microwave Ovens
Kenmore gas stove not coming out of pre- heat model 66575842001
This sounds like a flame sensor problem. No signal from sensor will shut down gas valve. Check flame sensor position in flame/or replace
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 02, 2009 | Kitchen Ranges
Kitchen Ranges Logo
97 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
