Question about Audiovox Car Audio & Video
My amp turns off when the radio is on but it turns on when the radio is off
    Novelist:
  • 149 Answers
Maybe somebody hooked it up to the wrong wire behind the head unit-try disconnecting the remote lead from the deck to whatever its plugged into-remote leads are generally solid blue in color-i always run mine to the fusebox and it shuts off when the car is off and comes on when the car is on-same thing just different location-anyhow check that out and see if that has any bearing on your problem-good luck
Posted on May 30, 2009
My cb radio shuts off when i turn of the amp
Is the CB getting its power from the amp(?) By amp I will assume you are talking about a signal amplifier..
Oct 05, 2016 | Connex Radio Communications
I need help installing a rockford fosgate punch 75hd amp in my 2013 ford f150. I ran the power cable but now I'm having trouble finding the radios remote turn on/off lead. Took the dash apart and...
If u are using a factory radio it may not have a remote turn-on (Usually the blue wire on the main connector to radio. and do not connect to any blue wire without checking the voltage) if there is not blue wire (remote) you can connect your amp to the red 12v (accessory) wire which will turn on amp when key is in accessory position and works the same and will not hurt your amp. If u do use this method and a pop is introduced when turning on radio and amp may need to purchase a relay to delay the amp turn on.
Sep 27, 2013 | Car Audio & Video
How do i install a new radio i dont know what colors are what for a 2002 galant
MITSUBISHI / GALANT / 2002 / Audio
Radio 12v red/white + radio harness
Radio Ground (chassis)
Radio Ignition blue + radio harness
Radio Illumination green/white + radio harness
Factory Amp Turn-on
Power Antenna N/A
LF Speaker +/- white/blue - black/blue +,- radio harness or amp
Notes: The amplifier is under the passenger seat.
RF Speaker +/- white/red - black/red +,- radio harness or amp
LR Speaker +/- yellow/blue - gray/blue +,- radio harness or amp
RR Speaker +/- yellow/red - gray/red +,- radio harness or amp
Mar 16, 2011 | 2002 Mitsubishi Galant
My amp stay on when the car cuts off. the only way it turns off it i take the fuse out the power line or if i disconnect the remote wire. I have check the remote wire behind the head unit it everything is...
connect the red wire of the amp to a car battery (+). the black to a car metal and the remote cable to the blue wire in radio. when you turn on the radio the amp turn of--when you turn off the radio the amp turn off.
Apr 26, 2010 | Lanzar Vibe 1200D Car Audio Amplifier
2002 kia speaker system diagram
It all depends on the Kia model but here is a diagram to get started with.
Radio Wiring Information:[B/]
Radio 12v red + radio harness
Radio Ground black - radio harness
Radio Ignition orange + radio harness
Radio Illumination red/orange + radio harness
Factory Amp Turn-on pink + radio harness
Power Antenna white + radio harness
LF Speaker +/- black - yellow +,- radio harness or amp under driv seat
RF Speaker +/- red - blue +,- radio harness or amp under driv seat
LR Speaker +/- orange - green +,- radio harness or amp under driv seat
RR Speaker +/- white - brown +,- radio harness or amp under driv seat
Mar 27, 2010 | Car Audio & Video
I need a stereo wiring diagram for a 1991 ford escort four door sedan
Good luck and hope this helps, keep me posted if you need more information.
Radio 12v dk. blue/red + radio harness Radio Ground black - radio harness Radio Ignition dk. blue/black + radio harness Radio Illumination dk. green (dimmer) + radio harness Factory Amp Turn-on red/black + radio harness Power Antenna N/A LF Speaker +/- purple - dk. blue/orange +,- radio harness or amp near radio RF Speaker +/- dk. blue/white - white +,- radio harness or amp near radio LR Speaker +/- white/dk. blue - red/dk. blue +,- radio harness or amp near radio RR Speaker +/- white/dk. green - dk. blue +,- radio harness or amp near radioclear.gif
Jan 15, 2010 | 1991 Ford Escort
I need an elecrical wiring routing diagram for a
Radio 12v, blue/red, +, radio harness
Radio Ground, black/yellow, -, radio harness
Radio Ignition, orange, +, radio harness
Radio Illumination, lt. green/red, +, radio harness
Factory Amp Turn-on, blue/black, +, radio harness
Power Antenna, N/A,,,
LF Speaker +/-, red - white," +,-", radio harness or amp
RF Speaker +/-, blue - yellow," +,-", radio harness or amp
LR Speaker +/-, purple - pink," +,-", radio harness or amp
RR Speaker +/-, white/blue - black/blue," +,-", radio harness or amp thats for non bose 04
Sep 21, 2009 | House Brand Car Audio & Video
Radio works but no sound. 02 Buick Rendezvous.
you have to find the amp turn on(it might be solid white) wire for the amp from the wire harness and hook it up to amp turn on on the radio
Jul 13, 2009 | Car Audio & Video
Jl; audio 500 amp
I assume the signal sensing switch you are talking about is the remote turn on for the amp. The amp should turn on when you turn your radio on, not your truck.
First try disconnecting the remote turn on that comes from your radio. After that is removed turn your radio on and them run a jumper wire from the positive voltage terminal of the amp ( the main power input) to the remote turn on terminal of the amp. If the amp turns on and you hear music, you have a problem with the remote turn on from the radio. If the amp turns on but you hear no music you have a problem with the audio input of the amp or the wiring of the speakers. if the amp does not turn on you have a problem with the amp.
I think you may have a problem with the remote turn on output of your radio. if so, you need to get the radio looked at by a service technician.
If the amp is turning on sometimes, you may just have a loose wire or faulty ground. Double check all the wiring.
Mar 18, 2008 | Jl Audio 500/1 Car Audio Amplifier
Car Audio & Video Logo
51 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
