Question about Dryers
Whirlpool nay gas dryer will not ignite flame Model #GGW9200LWO
  • 332 Answers
Is it new with a piliot or electric ignitor, if is is piliot you could need a thermocoupling, if it is an electric ignitor you will need to change the ignitor, both are eazy on a dryer you have alot of room to do this, if it is an ignitor do not touch the carbon but take it out and take it to an appliance store that as parts, you must have it with you so that the hold down braket is the same and the plug is the same, if it is a thermocoupling it is just a screw that holds it in place and you can pull it out of the holder you don't have to be so gental, but it must be pushed all the way in the holder till it clicks
Posted on May 30, 2009
    President:
  • 1,136 Answers
Hi, Remove the front lower panel so you can see what is going on. If the ignitor glows but gets no flame, you will need to replace the coils on top of the gas valve.
If the ignitor does not glow, check the fuse first and then thermostats to see if they have continuity..
THey are located on the blower housing.
Please let me know if this helps you or if I can assist you further.
Vic
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
I have a whirlpool gas dryer model#LG5801XKGO.
Whirlpools are great. There is a flame sensor near the igniter, it gets dusty and can't sense the flame. Carefully wipe it off, without bumping the igniter, it's super delicate. Sometimes the sensor can be removed for cleaning, just held in place by a little screw.
Nov 26, 2013 | Whirlpool Dryers
Tick noise gas line from gas dryer up to kitchen stove
sounds as if you igniter is trying to continually lite not sure about how flame senser works on that model but normaly senser is right next to flame may have been bent away from flame I am use to older models
Feb 07, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My gas Dryer turns but does not heat up. I don't see nay flame. I would liek to repair it myself. I appreciate your help.
Hi
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3. Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4. Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5. Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps...
Daniel
Oct 20, 2010 | Kenmore 74602 Gas Dryer
My whirlpool gas dryer keeps coming up with E1 error code after drying for about 50 min, model ggw9200lwo. Any solutions to what the probelm might be?
The E1 code means there is an open thermistor. This thermistor is located on top of the blower housing. Access it by removing the bottom panel on the front of the dryer. This device is not repairable, so unless it's just a loose connection or the device is not firmly mounted, it will need to be replaced.
Unplug the dryer before you work on it!
Mar 28, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Gas Dryer Problem
I would change both coils anyways,they can go bad after they heat up.
Nov 02, 2008 | Whirlpool Dryers
Dryers Logo
365 people viewed this question
Top Dryers Experts
