Question about Maytag Neptune MAH9700 Front Load Washer
Door won't unlock
I am unable to unlock the door on my washer. when i turn it on and try to start it the 'door locked' indicator is lit up and it makes a humming noise but the drum won't turn. pls help Door locked. Lights on the panel light up, but nothing happens. Have tried the "Spin Only" cycle per Maytag's suggestion, but nothing. Have unplugged machine and turned off water supply, but nothing when plugged back in after an hour. Is there a manual way to unlock the door to the MAH9700 model?
  • mareliserobi May 30, 2009
    I don't see a cancel button on the MAH9700 model of the Maytag Neptune washer. The manual syas that to cancel a cycle, press the power off button, select spin only, and press the cycle selector dial.. I have done this, but nothing happens.
    I got the door unlocked. Thank you. Only problem now is that it still won't run through a rinse and spin cycle.
  • 332 Answers
Try the cancel button it will drain the water and release the lock
Posted on May 30, 2009
  • 1 more comment
  • gary miller
    gary miller May 30, 2009
    it looks like you are in a bit of a problem, if you hold the on off button in nothing happen, well I do know the door is only locked because it has water in it, there is one other way I can think of. take a bucket remove the drain hose off the back and let the water out I actual think if you take the bottom cover plate off, the is a drain plug there and might even be an emergency relaease button or wire to pull to open the door but the big this is it will not open with water in it,
  • gary miller
    if there is a bottom cover on the machine take it off. there is a drain behind it drain the water into a bucket then look and there should be a release cable to pull to open the door, it will not open if the water is in it, so it has to be drained the computer won't let it at all
  • gary miller
    it might be time to have the tech come ot and get everything back in order, if you can get the front cover off, as i recall this is the one that was spinnig like it was not balcnced get the cover off and you will probly find something hung up in the drum or in the belt
It says CONTROL LOCKED.... how do I get it unlocked??
  • Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
  • Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
  • Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
  • They designed that mostly for kids sorry pain I know just be calm feel saving some ones child thanx
    Dec 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
    Door won't unlock and the washer will not start to fill.
    Check and see if the door is jammed or there is fault in the lock.
    Click this link for tips to reset the lock: Door lock
    Check the continuity of the door switch and see if the harness connects to the control board to trigger the start cycle when the door is closed.
    Jan 21, 2013 | Maytag MHWE200XW Washer
    Control lock lit, no other buttons work
    Instructions
      • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
      • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
      • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
    Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
    Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
    Lid Locks- Fills for 2 seconds and stops
    see this causes and fix it. God bless you
    Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
    Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
    Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
    Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
    WFW94HEXW door won't unlock and Door Lock isn't lit
    if you machine is warranty you must call to the whirlpool, and get the assistance via online chat. However you must wait about 180 seconds since you did the command STOP, and stop the motor, fi the water level is higher must be drain before the latch door unlock.
    2) if do not obey press and hold END OF CYCLE, wait about 10seconds
    3) reset the machine unplugged from wall by 45 minutes, and then plug again, and turn on and unlock the door
    God bless you
    Jun 21, 2012 | Washing Machines
    Washer error code dlf
    Hello and welcome to FixYa
    DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
    Kevin
    Dec 01, 2011 | Kenmore Elite 45986 Front Load Washer
    Hi! We have Kenmore Elite he3t. We noticed water in the washer today after a complete cycle so we ran the rinse and drain command on it. I tried to begin a new load on a normal wash cycle and it will...
    Kevin
    Aug 30, 2011 | Kenmore Elite 45986 Front Load Washer
    Maytag Neptune MAH9700 Front Load Washer Logo
    462 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
