Question about Kenmore 73952 Gas Dryer
Dryer will not heat up
Kenmore series 80 gas dryer runs and will not heat up what if you cdon't see the igniter glowing? 80 series
  • 332 Answers
If the ignitor doesn't glow it could be broke it is vary fragile, and made of carbon, you might want to have a tech come out, if you can see it with a flash light it has 1 screw that holds it in place if you can get it out unplug it, take it to R.E.Michaels a supply house over the us if not look for an appliance co, that has parts and you have to get the one with the same plug and hold down. you can instal it your self but remember do not touch the carbon part, it is sensitive to the oils in your skin only handle with the hold down,, if you touch the caron as soon as it lights up it will break, no doubts in that----good luck
Posted on May 30, 2009
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
Dryer runs fine but heating unit will not ignite
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
Feb 03, 2010 | Kenmore 62802 Electric Dryer
Kenmore 80 series gas dryer has not heat
most of these dryers have a little plastic plug on the front, left side. pop that plug out and look inside after turning it on. you should see a red glow. if not, then your ignitor has broken. if you see a glow, then the problem is probably one of the two little coils on the gas valve. these coils will sense if there is something to light the gas [the red glow] and open the valve - if the coils are bad, they won't open the valve
Aug 17, 2009 | Kenmore Dryers
Kenmore 80 series Gas Dryer
HI. you are correct. this dryer, although gas, is using a Glow igniter system. most older models used the snap igniter that clicks over and over to spark the burner but, this dryer is only 2 years old so, it should be outfitted with a glow igniter system. This igniter is powered by electricity.
It works in conjunction with a Flame sensor.
Jun 02, 2009 | Kenmore Dryers
remove the plastic tab infront of the machine
start you dryer. look inside the hole to see if the igniter glows.
takes 20-30 secnds.
if it glows then move to the back side of the dryer
remove the screws an check the thermal fuse, for continuity is your tester has the beep sound wich is easier to use for newbies, try it no beep sound, no good.
but if it checks ok then you probaly have bad coils
also since you are looking onthe back make sure that the vent is not restricted, a restricted vent can cause blow back an shut the dryer off if the vent is not clearly open.
good luck!
May 25, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer does not heat
I have a kenmore series 80. Had the same problem...the fix was replacing the gas coils. The dryer would get hot for about 10-15min then nothing. The gas would stop firing but you could see the igniter glow over and over again. Hope this helps.
Apr 02, 2009 | Kenmore Dryers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Kenmore 73952 Gas Dryer Logo
245 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
