Question about Quasar SP-3235 32" TV
Access code i have a quasar tv and i just got directv and some of the movie channels don't work the tv will say program rating exceeded access code required i dont know it the tv is pretty old and directv says the tv is locked and it has nothing to do with them please help
Hold power and action at the same time for 10 seconds
Posted on Apr 07, 2010
    Scholar:
  • 145 Answers
Sounds as though there is some type of channel parental lock turned on. Go the the MENU on the tv and adjust the parental control to off or lowest level. If it asks for a password, most of the defaults passwords are 0000, if it has a password needed at all.
Hopefully this will help you out.
Posted on May 30, 2009
  • Jeff
    Jeff May 30, 2009
How do I download the DirecTV app to my Roku streaming stick?
Roku is a streaming device to download the DirecTV app:·You have to press the "Home" button on your remote.·Scroll down and select the streaming channels.·Enter the "Direct TV"app now in the search box.·If require, you have to enter the Roku pin. ·Now DirecTV app will be installing on your Roku TV. Enjoy...
Oct 12, 2016 | Roku Televison & Video
How can i find remote control codes for my quasar tv
Hello
Three digit universal remote codes for Quasar TV are:
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit univeral remote codes for Quasar TV are:
0171 0148 0054 0170 0062 0374 0381 0003 0070
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. NB: Switch OFF and switch ON your TV, WITH ITS FRONT PANEL POWER CONTROL SWITCH, each time before trying an other code.
OK.
Feb 23, 2011 | Quasar VV-1301 13 in. Combo
What is the TV Code for programming the remote control for Quasar TV model # v v 2018 w ? Thank you.
Hello
Four digit universal remote control codes for Quasar Tv are:-
Three digit universal remote codes for Quasar TV are:-
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
OK.
Dec 08, 2010 | Quasar Televison & Video
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Hello I can hardly hear on all of my channels. I have directv and I can't get a reasonable volume. Is there something I can do to fix this problem?
Directv low volume problem.
One sure way to eliminate Directv's low volume and any other volume problems in general is by installing a stereo compressor between your Directv receivers audio outputs and your TV's audio inputs. (Simply plug the compressor's outputs into TV and your receiver outputs into the compressor's inputs). By correctly setting the controls on the compressor, you won't loose the dynamic program content. Not only will it raise the volume level to where you want it be, it will also prevent it from exceeding any set level you chose, actually limiting how loud any sound can be. These settings are fully adjustable. In other words when you switch from Directv back to a dvd or any source, no more sound blasting, you can set levels to be the same now since you have raised then adjusted Directv's level to normal. Plus a compressor will raise those low hard to hear audio sections often found in movies. This is the reason we used them all the time in the recording industry. Another benefit is it levels all channels on Directv. The result, channels are now the same volume. This is what I'm doing to end the problem. Hope this helps someone. J Pynckel
Jul 27, 2010 | Directv H21 DTV Receiver
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Quasar model VV2008 tv/vcr
in side the mother board(kit)  there should be vertical IC gone.   check the vertical section  for  the IC number  and  replace it  ,     this  will solve ur problem
thanks
Oct 26, 2008 | Quasar VV2009 Combo
Quasar TV access code for parental control
same problem as discribed on a Quasar sp2722 0000 didnot unlock the parental control
thanks
Feb 09, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Remote control code to program for directv receiver
i have a ton of codes i need your model# of your Directtv Receiver.
Feb 05, 2008 | RCA DRD430RG DirecTV DTV Receiver
Quasar SP-3235 32" TV Logo
196 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
