Question about Panasonic NV-DS30B Mini DV Digital Camcorder
Canon mv901 wont playback
As the heading says, the camera won't playback. Or else it won't record, I'm not quite sure. But when I "record" something and then try to watch it, the screen stays blue like there's nothing recorded. Please help!!!
Also what kind of cord must be bought to put the recorded data on to the computer?
thanks!
Celeste
  • lenagain Apr 19, 2009
    need to no what lead is required from cam {
    mv901} to pc please. len.
Same problem here!!!
Posted on Dec 29, 2007
SOURCE:
Wont record
Probably the pins in the video head are broken. you have to change the video head.
Mar 04, 2013 | Canon ES400V Camcorder
I have a canon sd 1100 camera with video recording. It no longer records the sound with teh video and I don't know if I hit a button or if it just broke. any thoughts?
If you're not hearing anything on playback on the camera, try pressing the up-arrow during playback to increase the volume. If you're not hearing anything on playback on a computer (and neither the viewer nor the computer are on mute) then something is broken on the camera, causing it not to record audio.
Jul 06, 2010 | Canon PowerShot SD1100 IS Digital Camera
Recording playback has lines through it.
try with head cleaner tape 2 or 3 times mostly it works if not change video head assembly
May 24, 2010 | Canon ZR200 Mini DV Digital Camcorder
Wont record anything to MiniDV tape and A/D randomly working
Sorry about delayed reply as I just saw it.
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Regarding can't see picture or time code in playback, it is problem of dirty / clogged video heads. Use good quality video head cleaning cassette to clean heads and hope camera will show playback picture.
Good luck.
Nov 19, 2008 | Canon ZR85 Mini DV Digital Camcorder
Cant download driver for mini dv camcorder mv901
The only way to get your Recorded videos from your canon MV901 is to get a cable called Firewire IEEE 1394 cable (buy it on Ebay, original cable coast 25 punds)however there is one big problem with that cable, most of computers dosent have the port for it, so first check your Pc if it has the right port for that cable before buying it!
There is another cable for Mv901 called USB, al of the Pc's have the port for it and it coast less that the Firewire IEEE 1394 cable, but again there is one issue, My pc cant find the correct driver for it and i cannot download a propper driver from anywhere... So i suggest the USb is kind of useless because you cant get a friver for it.
May 23, 2008 | Canon Cameras
Solid blue lines through Picture on playback mini DV PV-gs19
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Apr 21, 2008 | Panasonic PV-GS150 Mini DV Digital...
Panasonic Digital Video Camera (Mini DV) - horizontal stripes
I am having the same problem with my Canon Optura 60. But only in playback.
Jan 08, 2008 | Video Cameras
Gray lines across video screen during playback
my canon zr 200 in playback is fine but when i turn it on to record i have multi colored bars on screen and wont record
Jan 06, 2008 | Canon ZR200 Mini DV Digital Camcorder
Canon Gl2
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 18, 2007 | Canon GL2 Mini DV Digital Camcorder
Panasonic NV-DS30B Mini DV Digital Camcorder Logo
212 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
