Is there any way to clean a fairly blocked muffler for a RBC 3300A brush cutter?
SOURCE: i have a ryobi brush cutter rbc 40sb the pull
Hi there
A chainsaw or small engine repair shop may have the part.
If not, Click here for the Ryobi Service center locator page. Just enter your zip or area code and it will display a list of the nearest Ryobi service centers.
Hope you find this very helpful
Best regards
Mike
SOURCE: How to remove the clutch
Remove the clutch housing...should be a small Torx head screw in the neck of the housing, screwed into the threaded end of the crankshaft. Once housing is off, rap on the solid inside ears of the clutch with a small hammer and flat-head chisel..counterclockwise. If stubborn,don't beat it to death. Use penetrating oil on it and try again later. It will come off.
Please vote on this solution.
