Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Water dispenser problem
Newly installed fridge (5/27/09) -- Whirlpool side by side 21.8 cu ft with PUR water filter and in-door ice maker. The man who installed the fridge said to wait 24 hours until the first batch of ice was made and to throw it out along with the first gallon or two of water. Well, the water finally came out but it has been days now and I have barely gotten a gallon of water to flow out of the dispenser. The icemaker seems to be making sufficient ice and yet the water does not flow out of the dispenser appropriately. The stream starts okay for about one teaspoon of water and then immediately becomes an extremely thin drip then nothing. I even removed the filter to see if that is what is holding it up and the problem remains. Doesn't it seem like all the air would be purged from the lines by now? Please advise.
  • 37 Answers
Did the man who installed it use plastic hose or copper pie? PLastic pipe can get crimpled (closed) and starve the water supply.
Simply move the refrigerator far enough away from the wall and see if the tubing is crimped. If it is copper and it is crimped- you should call the installer back to repair the copper pie. Once copper pipe is crimped- it is unusable and must be refitted with a coupling or union or some other proper repair.
Maybe this is all that is wrong.......
Hope this helpes!!!
Posted on May 30, 2009
Diagnostics check say water valve is off
there is two seperate water valves first insure that water lines coming and going to tank are not frozen..if not replace inlet valve on back of fridge
Jan 11, 2014 | Whirlpool 21.8 cu. ft. Side-By-Side...
ICE MAKER IS NOT WORKING BUT WATER STILL COMES OUT OF THE FILTER WATER SIDE OF THE FRIDGE
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
dashghsd34
Sep 08, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Ice maker
filter its on the kick plate @ the bottom of the freezer door,push the side button and the filter unlocks
Jun 17, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Problems after replacinf waer inlet valve...
yea that is common just switch the wires and then try to get water out the door.. no biggie you wont hurt nothing... the water just wont come out the same place...
Apr 30, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
Mar 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Has anyone successfully fixed his or her water dispenser?
I have had a few where the water switch housing that holds the switch breaks and does not allow the arm to hit the switch to turn water on. that is one thing it could be ethier way not to big of an expence to get fixed
Feb 23, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
140 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
