Question about Avid Shorty 6 Cantilever Brakes Front
Removing a roll pin that is seized in an adjustable bicycle seat post.
I cannot remove the roll pin from the Joplin (Maverick) adjustable seatpost to convert it to the remote system. The instructions show it coming out easily but even with the right tools it won't budge.
Had the exact same problem. It seems some models use a solid pin that is very difficult to remove, whereas later models us a split pin that is relatively easy to remove. I had the older model that I couldn't budge. Ended up removing the saddle clamp mechanism and taking it to a machine shop. Several forceful hits with a large hammer, a proper punch, and a table-mounted vice and it eventually moved! My advice would be to find your local machine shop and see if they can do the same for you.
Posted on May 04, 2010
Seat post shim
Hi, 27.2mm is a standard size for a seatpost, popular sizes includes 30.9mm om newer mountain bikes and 31.6mm on older since it stadardized to some extent. There are still many other odd sizes out there on mostly older bikes.
If you can, get a seatpost that is 27.2mm that fits directly into your frame, with no shim if possible. that will only add weight and creaks.
Also keep in mind that the length is important when you specify a seatpost. You can use websites like this to see what is possible/available before you order:
Seatposts Chain Reaction Cycles
You will also have to consider if you need some setback, if the seat clamp is directly on the post, it is called a zero setback post like this:
Mar 04, 2014 | Giant Boulder Se Mountain Bike 19"...
How to adjust seat height on 564 model
the seat is attatched to the seatpost...the seatpost goes into the frame...just behind where it goes into the frame, there is a bolt, loosen it and the seat should move (you might have to play with it) raise it to where you need to and retighten the bolt. But make sure you don't go higher than the maximum height, it's marked on the post or you could damage the frame.
Jul 11, 2013 | Cycling
In need the instructions
This is a seat post mounted bag, with attachments for the rails (2) on the bottom of the seatpost.
1. The straps going over the top of the bag will have to come apart. Removing them from the loop they pass through before re-attaching with the velcro.
2. Undo the straps and then feed them over the metal seat rails.
3. Re-assemble the straps in the same manner they were before and loosely attach the velcro. You will later tighten up the tension on these straps to snug the bag up under the seat.
4. Attach the velcro strap on the posterior of the bag to the seatpost.
5. Now the bag should be supported by the seat post strap and the seat rail straps (2). Hanging loosely and oddly from the seat area.
6. Tighten/snug the straps from step three, so the bag is drawn up against the bottom of the seat. Try adjusting all the straps on the bag until the bag appears to sit well under the seat.
7. DONE
Jan 05, 2013 | Avenir Bigmouth Seat Bag
Tryin to find the size of the seatpost
Bicycle seatposts are measured in tenths of millimeters. A typical size might be 26.4mm. Because of this you should either A) remove your old seatpost and saddle and bring it to a bike shop or B) measure the diameter of your seatpost with a pair of metric calipers, preferable digital. You can buy them for under $20 from someplace like Harbor Freight. Suspension seatposts tend to come in one (smaller diameter) size and are fittted with the appropriate size shim. Another possibility is an adjustable shim, make just for bicycle seatposts. I highly recommend your local bike shop.
Nov 10, 2011 | Schwinn Meridian Adult 26-Inch 3-Wheel...
How to adjust seat higher
Loosen the seatpost clamp and raise the seat. There is a safety line for maximum height, do not go beyond this point. If needs to be higher than safety line, get a new longer seatpost. Maybe a time for upgrade to a 16" or 20" bicycle. Lots of used ones out there and very cheap in cost.
Jun 30, 2011 | Huffy 12 in. Girls Disney Princess Single...
Bmx bike has no seat post how do i put a seat on ?
You will have to buy a seatpost, either pivotal or railed depending on your seat. A railed seat has two rails underneath it, and needs a railed seatpost. A pivotal seat has a prism with teeth cut into it on the bottom, and requires a pivotal seatpost.
Oct 18, 2010 | Dmm Animal Stump Pivotal Bmx Bike Seat...
How do you raise the seat?
  • The seat connects to the seat post and the seat post inserts into the seat tube
  • you will have to first loosen the seatpost clamp located where the seat tube meets the seat post.
  • after loosening, you should be able to raise the seat to your desired height, just don't forget to tighten teh seatpost clamp.
Aug 19, 2010 | Huffy 26 in. Cranbrook Cruiser Bike
Its real spongey, when i sit on it? what did i do and how do i fix it? is there an on line manual
Visit this link for instructions:http://www.crankbrothers.com/support/faq_seatposts_r.php
Aug 15, 2009 | Crank Brothers Joplin Adjustable Seatpost...
Bianchi Alu. seatpost seize in an Alu. frame. How
If you have a rubber mallet remove the seat from the post and loosen the bolt that secures the post in the frame. Bang the post from different angles around the top end with the mallet. Eventually you will get a small space happening where the post goes into the frame and you can spray some penetrating oil or lubricant around this gap. Eventually it will penetrate down and break the bond between the two parts. Install the seat and tighten it down enough so you can use it to twist the post back and forth or use vise grips or pliers. Remember though that if you use vicegrips or pliers that you might have to buy a new post. Keep twisting and banging the post and applying the lubricant and you should be able to get the post out. Aluminum does not rust it anodizes. It is a chemical reaction that occurs like rusting. Hope this helps.
Aug 06, 2009 | Cycling
I bought a new seat for my 1996 Fuji Sagres. The old saddle clamp is too narrow for the new seat rails. Where can I buy a different sized saddle clamp that will fit my bike?
take it to a bike shop and get a new seatpost. bike shops
have manuals that they can check to find a seat post that
fits the bike frame and has the proper size rails to fit your
new saddle.
this is a good time to upgrade the seatpost, you can get one
that is lighter and more adjustable that your old one.
Jun 06, 2009 | Cycling
Avid Shorty 6 Cantilever Brakes Front Logo
154 people viewed this question
Top Avid Cycling Experts
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
John Egan
John Egan
Are you an Avid Cycling Expert? Answer questions, earn points and help others
