Question about Dishwashers
Bosch 2006 SHU43E door will not lift from horizontal position to close"
"Bosch 2006 SHU43E door will not lift from horizontal position to close"
  • 332 Answers
The bosch is only on a hinge there is either something in the slot for it to retract into or one of the hinges is bent and won't let it up. there are springs on the sides of the dishwasher but you have to pull the unit out to get to them to make sure it isn't hung up on anything
Posted on May 30, 2009
2006 jeep liberty rear lift glass won;t close
Mine did this too....the latch kept getting stuck. If you put the key in the ignition and unlock the power doors, pull on the gate door (don't open it, just enough to release the latch), and it should come out so the hatch will latch.
Feb 18, 2013 | 2006 Jeep Liberty
Hi the right hand hinge of the door has popped out whilst I was trying to move the oven using the door handle as leverage. The door is now wonky when closed as the hinged has popped out. Help!
All oven door typically lift off the hinges by design. If you open the door to what is referred as the broil position. You know when the door stops about 4 to 6 inches open at the top. Then do the following.
1. Lift the door up completely off the opposite hinge still in place and remove. Set the door aside carefully as if has glass window, you do not want to break.
2. Then set both hinges at the broiler stop position. If one is all the way in to door fully closed position pull it out with your hand or with pliers till it stops @ broiler position. If all the way down as if door was fully open, lift hinge until it stops at broiler position. CAUTION- THE HINGES ARE SPRING LOADED AND CAN SNAP BACK INTO FULLY CLOSED POSITION. You can use a heavy glove or if you have an oven mitten, that can work to protect your fingers. DO NOT GET YOUR FINGERS BETWEEN HINGE AND OVEN OR CAN PINCH FINGERS.
3. Now carefully lift the door over the hinges set at the broiler position. Careful not to bump them when doing so or can snap closed. If does, reset hinge to broiler position and repeat. Works best to hold door at angle that door is when in broiler position. Once you have them started evenly, you should be able to fully slide down back onto both hinges.
4. If one of the hinges no longer has spring tension you have to reattach the spring. You can usually access spring if needed by removing the bottom drawer.
Aug 27, 2011 | Ovens
My Bosch built in Dishwasher has developed a problem in that the door will not close. Additionally when I presss the on/off switch to on the dishwasher works without the door closed. How can this be solved
sounds like a fixer but check the seals around the door then besure the door is on its track they work like a stove door if you lift a certain way it get out of line and won't close tracks are on the lower sides of the door
Sep 26, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My back doors wont close all the the latch is in the down position ....how or what can i use to fix them the kids push in the latch ..its a 2006 bmw x3 sports edition
TAKE A SCREWDRIVER OR SOMETHING TO PUT IN THE GAP IN THE LATCH WHERE THE STIKER IN THE DOOR JAM IS WHEN IT IS CLOSED NORMALLY,& WHILE YOU HAVE THE SCREWDRIVER OR SOMETHING SIMILAR IN THE LATCH,PULL TOWARDS THE CAR WHILE YOU PULL THE HANDLE LIKE TO OPEN THE DOOR AS IF IT WAS CLOSED NORMAL,& IT SHOULD OPEN THE LATCH.
Dec 05, 2009 | 2006 BMW 3 Series
Our Bosch SHY66C05 door latch is stuck in locked position
you have to pull back the spring or replace the lock. the repair is pretty easy.let me know what happen.
Nov 07, 2009 | Bosch 24 in. SHY66C05 Stainless Steel...
Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
May 30, 2009 | Bosch Evolution 500 SHE45M06UC Built-in...
Garage door gears misaligned
I got it... I moved the take up wheels that the cable wraps around to their outermost position and it's keeping the shaft from moving. kinda scary though, I don't like working around those torsion springs.
Feb 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Not Drying
I found that if the rinse agent (Jet Blue) has run out the dishes stay wet.
Aug 21, 2008 | Bosch SHU3305 Dishwasher
The Rinsing aid door keeps opening in my Bosch dishwaser
I believe paddy55 is correct about the rack position affecting the rinse agent door. When the top rack is moved to the higher position, the rack hits the latch on the rinse agent door, causing it to pop open.
Move the rack back to the lower position and see if the door stays closed.
Apr 06, 2008 | Dishwashers
Bosch 500 series Front Load Washer Door hanging a bit lower than when purchased
Even if you do not realise it most people lean on the door as they open it, to rectify with the door open but almost in the closed position lift the door by pulling up on the door catch end, this will straiten the hinge, very common problem Regards Engineer
Jul 26, 2007 | Bosch WFMC 3200 Front Load Washer
Dishwashers Logo
78 people viewed this question
Top Dishwashers Experts
