I need a 24" x 1/2" white down rod for my Aloha Breeze ceiling fan, where can one be found? Have checked several places - no luck! need a down rod for Aloha fan! Why sell them through WalMart and not give them a down rod????
No Home Depot or Lowes is going to carry a 36in long mount for any fan. I know! Most hanging mounts are just 1/2in. NPT, galvy pipe anyway. You can usually make a rod mount out of the 3in. or 6in. mount that usually comes with most fans. Just unbolt the mounting from the short mount and bolt it on to the 36in long 1/2in. galvy. Paint to suit and presto, for about $8 you just created the downrod you need! If you can't make that work, you can always call Aloha fans and order the length you need. If you can't get ahold of Aloha, try Hunter, or Casablanca. I do believe that Casablanca can fix you up. They did our Aloha fan rebuilds when the control modules burned up. We thought it was the switch\controller. it was the module IN the fan itself. Let us know what your results are.
Was this helpful?
Yes
No
Popular Solutions for Aloha Housewares Ceiling Fan
switch on 3 speed 4 wire ceiling fan fell apart.what color wire goes to what number position on...
(More)
switch on 3 speed 4 wire ceiling fan fell apart.what color wire goes to what number position on switch. fan model #4745(79757).fan upc code#7-59590-79757-8.switch is shine top ls-102
I need screws for my hugger series ceiling fan. They are the ones that mount the blade assemblies to...
(More)
I need screws for my hugger series ceiling fan. They are the ones that mount the blade assemblies to the motor. I tried the standard ones sold at Home Depot but they are too small. Need just a little bit fatter ones. Not sure what size they are. The ceiling fan was pre installed in a 2003 travel trailer Thanks, Janine The Aloha Housewares fan listed below may not be the one I have. Mine has a stock # of 5445-42W.
blade arm style no 20006 its broken im my fan why i need to order because i call and live a mesage...
(More)
blade arm style no 20006 its broken im my fan why i need to order because i call and live a mesage and no vary ansuer my phone its 561 281 6360
