Question about Kenmore 62802 Electric Dryer
Dryer produces low heat but not high heat
    I couldn't find the exact model on your sight but it is an electric Kenmore model 62212 and appears to be less than 5 years old. There are too different cycles on the dryer. 1 is a preset low-heat setting and the other is a timed high-heat setting. The problem is that the dryer will only produce low heat when on the high heat setting.
    I did notice when I went to dry my first load that there was a lot of lint inside the dryer. I cleaned out the dryer and the lint trap. After an hour on the high heat setting, my clothes were warm but still wet. It took 4 1hr cycles to dry the clothes.
    I figured maybe the guy before never cleaned the lint trap so maybe it was clogged. I removed the rear panel, removed the lint trap duct and gave it a good cleaning. After reinstalling the duct and before putting the rear panel back on I turned the dryer on to see if the heating element was working. It glowed but went on and off frequently. It seemed to be working but it is not staying on long enough to produce high heat. I don't know if it has a thermostat that might be bad or maybe part of the heating element may be bad. My landlord is considering buying a new dryer. Any advice will be sincerely appreciated.
Thanks,
Andy
  • travisthumb Oct 22, 2007
    Additional information. I just put a load of towels in about an hour ago. Still the same wet but I noticed that the lint trap doesn't have much lint in it and that there is a lot of lint stuck to the inside of the dryer. It seems the lint isn't making it's way out of the dryer into the trap. Please help.
    Thanks,
    Andy
  • Anonymous Mar 28, 2014
    No heat, replaced low and the high temp. sensors. Replaced lint tray sensors
  • 126 Answers
Check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Posted on Dec 13, 2007
I have a Kenmore electric (front load) dryer, model number 84092500 that would spin but does not produce any heat. I tried cleaning/vacuumin the tubing that vents to the outside and resetting the circuit...
The first step of the fix has been done by cleaning the lint filter and the vent system.The next step is replacing the thermal cut-off and the high-limit thermostat both located on the blower housing. It is common that the dryer stops heating when the thermal cut-off blows open due to the failure of the high-limit thermostat to cycle off and regulate the heater temperature. The thermal cut-off cuts power to the heating element should the high-limit thermostat fails and the dryer temperature goes extremely high as a safety feature. Click on the links below for the troubleshooting and repair details.
Whirlpool and Whirlpool-made Electric Dryers (With Removable Back Panel) Not Heating
Whirlpool and Whirlpool-made Electric Dryers (Without Removable Back Panel) Not Heating
Jun 19, 2011 | Kenmore Dryers
Kenmore elite model 11062952100 My dryer will not heat I replaced The thermal cutoff and high limit thermostat the dryer produce heat briefly but is not producing heat again.
There is a high limit switch (looks like a button with two wires hooked to it) on the bottom of the vent frame. When the vent fills up with lent at the bottom it gets hot. For safety, this limit switch will turn heat off. Remove the vent frame and clean it out and check the continuity of the switch. Also, make sure both heater elements are working properly.
Jun 19, 2011 | Kenmore 63942 Dryer
I have a Kenmore 64812 (110-64812200) electric dryer that produces a high heat at every temperature level, even "delicate/cool" is hot. With two thermostats and a fuse, what could be broken first?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Thermostat is bad...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 05, 2010 | Kenmore 64812 Electric Dryer
LG Dryer not producing heat
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 03, 2010 | Dryers
Poor heat
Hi, Have you checked the venting to the outside? Is this gas or electric? If it is gas, it could be coils on top the gas valve. I want to help.
Vic
May 16, 2009 | Kenmore 73952 Gas Dryer
Always in high heat
I am assuming this is an electric dryer.
1) Thermostat may have failed.
2) Element may have broken at one point and shorted to ground.
Please reply your specific model number and I can help further.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Low heatworks, high heat does not.
it sounds like you need a set of thermo switches. one may have stopped functioning. a service tech can test them easily. should be low cost
Jun 28, 2008 | Kenmore 64202 Electric Dryer
Kenmore 62802 Electric Dryer Logo
522 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
