RAM I know my HP 742.uk pavillion can be upgraded to about 2 Ghz RAM, trouble is I do not know what to buy, 184 pin or 240 pin. All I know is that I need some DDR RAM. Can you help. Please advise. Best regards, Frank
  • m155ing Oct 22, 2007
    Can you help.
    Please advise.
    Best regards,
    Frank
How to copy new flash simm with
Posted on Nov 25, 2008
  • 24 Answers
See my friend dont get confused just go and ask for DDR RAM..I have checked your config..you need not worry..
The 230 pin RAM is DDR2 and dont worry about it..
See this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07618&lc=en&cc=us&dlc=&product=212431&lang=
I will be thankful if you rate this thread!
Cheers!
Jimmy Neutron!!
Posted on Oct 22, 2007
Can an old HP Workstation xw8000 Computer that is currently using 512 RAM (PC2100 registered 184 PIN ECC DDR SDRAM DIMMs) be upgrade using 4GB Kit (2 X 2GB) PC2100 Registered 266MHz 184 pin DDR SDRA
According to a couple of people I have conferred with, that RAM should work.
Take a stick of the old ram out and make sure the the cut out, in the new RAM, is in the exact place as the old sticks. It cannot be off by a micron, or it will not fit.
Understanding Identifying and Upgrading the RAM in your PC
Dont click on any of the ads in that article, just read it and you will be able to judge for yourself.
Mar 11, 2014 | Dell W4201C 42 in. Plasma HDTV
Can i upgrade my intel D845pesv mother board with 1GBDDR3 RAM ?
No, that motherboard only has two DIMM sockets that support 184-pin connections, DDR3 RAM only comes in 240-pincount. Your motherboard does support up to two gigabytes of RAM, so you could buy two 1GB sticks of DDR 184(pin) SDRAM DIMMs at 333/266Mhz (the speed of the ram)and install that.
Dec 22, 2010 | Intel D845PESV Motherboard
How much RAM can hp pavillion a700n computer support
I can support 2G i have that same comp and i got a 1g stick and a 512 stick.
Dec 11, 2010 | HP Pavilion A700N (PJ516AA) PC Desktop
Can i upgrade my packard bell 4340 imedia pc,it has an athlon xp 3000+ barton cpu,768mb ram in 2 slots,graphics-radeon 9200 series
You can upgrade the memory to maximium of 2gb of ram 1gb stick of ram in each slot. The memory you will need DDR PC 3200 184 pin.
You can also upgrade the hard drive for more space or buy an external drive to store files.
Jul 20, 2010 | Acer Computers & Internet
Can I upgrade my CPU to an Intel Core 2 duo 1.7
You are basically limited to what was optional on the model. So you can only upgrade to one of the following cpus:
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
And you are limted to 2gb of ram max on this model.
Apr 12, 2010 | HP Pavilion dv1000 Notebook
I purchased an HP Pavillion Slimline S3620f model# FK785AA-ABA Serial # CNX8330324 - KQ511-69002 Mother/system board FK563-6900Intel Core 2 Duo Processor #5200 2.5 Ghz Kc923-69001 2G Memory mododule...
ohh hp pavillion have 2 year warranty on the motherboard, but dont do it yourself, just call the customer care and ask them to resolve the issue, as system is still in warranty period, dont void the warranty yourself
Feb 09, 2010 | HP Pavilion Slimline S3123W Desktop PC -...
Can i upgrade my ram to ddr3 if so what would you recomend .cheers
Thank you for the clarification sir.
NO, the Fujitsu Scalio 600 Media Center uses the Gigabyte GA-8ISXT-FS motherboard, and it only supports DDR Sdram.
This is a PDF Motherboard Manual for the GA-8ISXT-FS mobo, from Fujitsu Support,
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/Boards/Motherboards/GigaByte/ga-8isxt/Man_8isxt-fs_uk.pdf
This is the support page for the Fujitsu Scalio 600 Media Center,
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/consumer/MediaCenter/Scaleo%20600/Scaleo%20600.htm
Uses either DDR Sdram at 333MegaHertz, or 400MHz.
(PC2700 and PC3200 respectively)
DDR Sdram has 184 gold plated contact pins on the bottom.
DDR2 Sdram has 240 gold plated contact pins on the bottom.
DDR3 Sdram has the same amount of contact pins as DDR2.
The voltage and signal contact pins are in a different place, from DDR2 to DDR3.
This is why the locating notch on the bottom of the ram stick, is in a different place, comparing DDR2 to DDR3.
So you can see, DDR3 not fit in a DDR2 slot, because the locating lug in the bottom of the ram slot, and the locating notch in the bottom of the ram stick. Keeps people from trying to put DDR3 in a DDR2 slot, and vice-versa.
You can also see why a 240 pin ram stick, will not fit in a 184 pin ram slot.
Bumping up from DDR to DDR2 does make a difference in my book. (Requires using a motherboard that supports DDR2 however, so you would need a different motherboard)
Going from DDR2 to DDR3? Not so much IMHO. The frequency rate is higher, but there is a trade off with slower ram timings.
Sorry if I have been too 'Windy', but I thought I would give you more information, than just,
'No, won't work', or No won't work because your motherboard uses DDR Sdram'.
Nov 18, 2009 | Televison & Video
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
Ram
the ram should not go higher then the MHZ or GHz you have
like 2 Ghz computer should not go over 2gig of ram
i hope this helps out
Jul 15, 2008 | HP Pavilion a422n (DW270A) PC Desktop
Ram card
Hi giovanni2,
Sorry but you're board does not support DDR2 memory.
Only 2 x 184-pin DIMM sockets support two 2.5V DDR SDRAMs (DDR400/333/266). There are two PC Chips M871G.
One is M871G (V1.5) & the other is M871G (V3.1). Neither support DDR2 memory. DDR2 memory used DIMM slots with 240-pin. The memory slots on you're board uses 184-pin. The board will not function with 240-pin memory.
PC Chips M871G (V1.5) link.
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=340&CategoryID=1&DetailName=Specification&MenuID=7&LanID=2
PC Chips M871G (V3.1) link.
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=368&CategoryID=1&DetailName=Specification&MenuID=7&LanID=2
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 22, 2008 | PC Chips M871G Motherboard
k24674
jasbo
jasbo
Marvin
Marvin
